993 Forum 1995-1998
Original Colour of the 993 Engine fan
Old 10-31-2012, 01:20 AM
Neil Perry
Neil Perry's Avatar
Default Original Colour of the 993 Engine fan
Hi
Does anyone know the original colour of the 993 engine fan as delivered from the factory?
Does anyone have the colour code?
I was told on the week end, it was a dull silver and not the grey brown that they are today.
Thanks,
Old 10-31-2012, 04:45 AM
kjr914
kjr914's Avatar
My original was a tan-ish color. I just installed a brand new one and it was a dull silver.
Old 10-31-2012, 06:18 AM
Neil Perry
Neil Perry's Avatar
Hi Keith,
Do you know what the colour of the new fan would be?
Can you describe the silver of the new fan?
I want to spray my fan the same colour.
Thanks,
Old 10-31-2012, 08:35 AM
ToSi
ToSi's Avatar
here's a new one:
Old 10-31-2012, 12:18 PM
Resident Sicko
Resident Sicko's Avatar
+993 Dull silver and the paint is so thin it doesnt last. Ofter time it wears away to a tan. The metal used on the fans was so low quality (porus) to prevent heat transfer that getting a good surface is darn near impossble.
Old 10-31-2012, 01:21 PM
David in LA
David in LA's Avatar
If I wanted to clean up and dress up my fan, what would be the better choice - spray paint, powder coat or anodize (assuming this were possible)?? TIA
Old 10-31-2012, 01:33 PM
mike cap
mike cap's Avatar
In order of durability......
Anodize
Powder Coat
Spray Paint
For cosmetic items on an auto or airplane I always try to go anodize first.
Old 10-31-2012, 03:39 PM
kjr914
kjr914's Avatar
ToSi's new, silver fan looks exactly like my new one. It is not a match for polar silver, sadly for me...might be a little closer for you arctic guys.
I powder coated my fan housing, then had issues getting the new fan to rotate cleanly....it had some paint bumps on the ends from shoddy manufacturing. I ended up sanding down the end of the new fan blades using sand paper held against the fan housing while rotating the fan by hand. Starting with very thin, low grit (high number) paper and moving up to thicker stuff. sucked and took a long time. If I were to do it again, I'd probably paint mine myself and go very lightly on the inner barrel with paint.
As for the fan, you need to control the thickness there as well, so I might just go with hand painting that as well, when I get around to it. Look for a post by Andreas on the fan/housing painting.
Anodizing sounds like it might be an idea as well due to thin coating, but check on the magnesium(?) alloy fan's ability to hold onto the anodizing.
Old 10-31-2012, 04:25 PM
bart1
bart1's Avatar
I think this is a cool fan:
http://forums.pelicanparts.com/porsc...e-racer-5.html
Old 10-31-2012, 05:54 PM
kjr914
kjr914's Avatar
Can anyone else (original owners?) confirm? Very interesting....quite a color change from silver to tan.
Old 10-31-2012, 06:00 PM
CarreraX
CarreraX's Avatar
Originally Posted by bart1
Hey, that is my fan! It was on my 3.2SS motor. I dipped it in some stuff (Ill look for the name) and then had the hub replated and then re-riveted it with alum rivets exactly like the factory did it. I really hat eit when people paint the whole fan and hub. And for the the fan now, it was just sold with the car and has made its way to So Cal....I miss that car!!
Here are a few more pics of it...
Old 10-31-2012, 06:14 PM
bart1
bart1's Avatar
Beautiful engine, Mark!
Old 10-31-2012, 06:44 PM
LvnTheDrm
LvnTheDrm's Avatar
You know...just when I think I'm a true-blue, down-to-my-bones Porsche fan--I see a post like this and realize I just don't have the juice. I'm second-tier. Poser. "Dipped it in some stuff" "had the hub replated" "re-riveted...like the factory." Who does this?! And, while we're on the subject...who cares what a fan--under the lid!--looks like? Maybe I'm just a surface P-Car fan...only pre-occupied with the quality of what you can see--from the outside. I'm not knocking those of you who repaint rotors, and de-gunk wheel-wells, etc...I'm just feeling a bit...unworthy.
Happy Motoring!
Old 10-31-2012, 06:51 PM
doc_porsche
doc_porsche's Avatar
i think when its powder coated in red it looks gorgeous
Old 10-31-2012, 11:17 PM
IXLR8
IXLR8's Avatar
Original color on my low mileage 993...a slight tan or very light gold color to it.
Quick Reply: Original Colour of the 993 Engine fan
