Just bought a 993 cab with 37000 miles on it. I love driving it and can't wait to leave my house tonight to drive some more.
I have an OBDII emissions questions:
I had a PPI on the car prior to purchase and the mechanic told me it came up with a secondary air intake fault code and told me it won't pass emissions in Washington state.
However, the car is not showing a check engine light and to my knowledge has "never" shown a check engine light in the past for this problem (assuming I trust the seller).
I bought a cheap ($70) obdii scanner. I plugged it in a bunch of times, and it shows that everything is ok. No faults or pending faults.
To sum up:
1. a mechanic has told me there's an SAI fault based on his professional obdii scanner
2. NO check engine light is on or has ever been on
3. Cheap obdii scanner says everything checks out.
I'm not sure what to make of this. Will it or won't it pass emission?
Appreciate any help you can provide.
the mechanic might have used durametric software which will show fault codes even when you don't have a cel. I have a cheap obd2 scanner which will show no codes even when durametric shows say a voltage fault code.
be nice if you can just get it smog tested as mike indicated and skip the obd2 flags.
Check your readiness codes and report back. A $70 OBDII scanner should have that capability. You may pass emissions but still fail if your readiness codes are not set.
It's good to know knowledgeable people. Thanks!
My obdii scanner has a function to determine if all of the monitors have completed their self-diagnostic testing, and it does show that they have, which makes me think that the readiness codes are set as "ilko" asked.
So, this makes me think that all systems have run their checks and come out "ok".
As "k77070" stated, my mechanic may be running durametric software that might show a fault even when CEL is not on. So does having "durametric" faults present in the computer predict failing emissions if there is no CEL and my obdii scanner is showing "readiness" without any faults shown?
Maybe, I'm giving this way too much thought. I don't want to bore anyone.
How many miles have you put on it since the ppi? The mech could have cleared the code and if you drove enough, you may have inadvertently set the readiness codes. Whatever the deal, go get it smogged now while the smogging's good!
As I'm sure you know, p1411 codes are very common in these cars!
I had the same issue, a few faults through their scanner which is all additional Porsche specific codes, but no CEL or standard OBD codes. I did have the battery disconnected and failed the first time until I drove it for a few days and everything reset. I don't think youll have an issue.
it could be used as a predictive sign.
if the mechanic is correct that there is an sai fault it likely means the check valve is dying and one or more sai ports are clogged.
you readiness flags will stay ready and you will pass emissions no problem until the sai ports are clogged enough to log a cel.
then you will have to clear the cel to pass emissions but after clearing the cel you will have to perform the drive cycle to set the flags.
check with wa state on that, if you could skip the obd2 test and just have them sniff test the car then you should still be good.
in utah for example it is illegal to have my car sniff tested, so I need to deal with the drive cycle garbage.
anecdotal story, durametric gave me an sai fault for almost 2 years without a cel, so you could be good for years(or days).
when I finally did the sai clean up process the check valve hadn't failed but three ports were very clogged and took lots of bicycle wire drilling to clear them.
Thanks for all of the advice. Very helpful. I just found out that I don't need to do emissions until next winter. I think I'll wait until then to worry about it and enjoy the car for now and through next summer. Can't believe I waited this long to purchase a 993. What fun it is to drive.
Be sure to see the "sticky" thread at the beginning of the 993 Forum on the SAI Circuit. Everything you could possibly want to know about this annoying situation is in there. Block out about 6 hours to read through it...!
