How to change battery...
It should look like this...
no, buy the correct grommets and don't worry about it.
The funny thing is when you've installed them, it almost looks like something is dangling down and needs to be fixed...
At the time, nobody seemed to know the part number of those drain tubes. I have them now, but I'll leave the rubber plugs installed for now. If I did use them, I'd stamp out some open cell foam and insert them into the tubes to keep dust down; my luggage compartment was dusty/dirty with them in place.
When you see the pic of these, you'll understand Quad's comment. Its more of a tube and has a right angle in it to prevent water ingress. If you search the part # on Pelican it has a picture ($3.25 each).
911-631-259-02
911-631-259-02
