993 Forum 1995-1998
Varioram Script on the manifold
Old 08-29-2012 | 04:09 PM
H.H.Chinn's Avatar
H.H.Chinn
I have the "Script" on mine built 12/97. I've seen some guys paint or polish the raised letters. I've not done either.
Old 08-29-2012 | 05:01 PM
77'3.6vram's Avatar
77'3.6vram
Default Your guess?
Originally Posted by Aircooled Dave
That said, I would venture to guess that the change was made to the existing tooling at some point in '96.
Cheers,
Dave
How do you explain the fact that all RS(95'-96') cars came with the scripted version?
Old 08-29-2012 | 05:03 PM
JM993's Avatar
JM993
The RS varioram manifold is different than the "standard" varioram manifold.
Old 08-29-2012 | 05:12 PM
XR4Tim's Avatar
XR4Tim
Originally Posted by JPP
I wonder what Detroit would have done?
They wouldn't have changed it at all. My GMC Typhoon says "Syclone" on the intake manifold if that's a clue.
Old 08-29-2012 | 05:29 PM
77'3.6vram's Avatar
77'3.6vram
How is the RS VRAM different from the reg.VRAM? The reg.VRAM intake has the special mounting holes used by the RS and factory supplyed 3.8 cars.I have called around and am told there is No difference between the top casting for the RS vs. Reg. 993's.
Last edited by 77'3.6vram; 08-29-2012 at 05:37 PM. Reason: Been told you are misinformed.
Old 08-29-2012 | 05:47 PM
NineMeister's Avatar
NineMeister
The runners have a larger bore diameter to match the 46mm intake ports in the RS cylinder heads.
Not that they needed to be, but that's another story entirely....
Old 08-29-2012 | 05:49 PM
NineMeister
JP: You shure is good at stirrin' up them there hornets, aren't you?
Old 08-29-2012 | 06:15 PM
tbil's Avatar
tbil
I've always thought the center flat spot on the intake cried out for some branding of some sort. Like they had something planned but never implemented. Porsched logo might be a little too cheesey but looks like it's missing a label or something.
Old 08-29-2012 | 08:23 PM
CarreraX's Avatar
CarreraX
I have the script on my 1/97 build C4S.
Old 08-29-2012 | 08:42 PM
JPP's Avatar
JPP
... I'm jus' out here shakin' the bush boss ...
Old 08-29-2012 | 08:43 PM
JPP's Avatar
JPP
... Oh ... and I wasn't lyin' when I said ... I have seen today with my very own eye's .. a 7/95 build car with a Varioram script manifold with 3K original miles on it!
Here's an RS manifold .. looks like some subtle physical differences on the outside as well ..
v.s. stock production
Old 08-29-2012 | 08:59 PM
e3photo's Avatar
e3photo
Like this?
Old 08-29-2012 | 10:24 PM
vincer77's Avatar
vincer77
I do find the lack of a capital V disheartening.
Old 08-29-2012 | 11:24 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
During the final pre-production checkout of the Boxster, Porsche discovered "a harsh and annoying rattle" (aka. resonance problem @ 2,250 rpm) with the intake manifold. Dupont and Mark IV (they designed and produced the intake manifold) discovered the buzzing/vibration came from right under the SCH In the PORSCHE logo. So they had to change the molds...
Old 08-30-2012 | 01:04 AM
il pirata's Avatar
il pirata
Does this mean all the 993s with Billy Boats the issue was the intake manifold with Varioram script?
