Supercharged 993 - Improving charge air cooling
#32
gt2rs intercoolers!
Here you go,I did this a while ago,with 3 cores, needless to say temps are very close to ambient,
more fun for the intercooler addict!
#33
Can you let me in your engine secrets? I'm looking into building a reliable 600-700hp track engine from a 993 turbo engine. I would be very interested in hearing how you reached 800hp, what your budget was and which parts did you use.
Meanwhile there is some progress with this intercooler setup. The Supercharger outlet plenum is ready now, it's not pretty but it works. So is the charge piping on the supercharger side. Next is the charge air piping after the cooler. That is the easy part as I have large radius 90-degree elbows which I just need to cut to correct lentght and put together with silicone hoses.
Finally I need to bring a pipe from the throttle body into the intake filter box which I need to design and fabricate.
And of course I need to weld in a bracket for the MAP/IAT sensor...
#35
King of Cool
Oh, and 1st call for buying your S/C kit when you obviously don't need it at that point!
IC looks good and nicely tucked in.
#36
SC (with all the gizmos) is yours, when I pull the trigger on the turbo in 1-2 years.
Got the grille and the wing blade from the painter. Black paint + matte clear coat. Looks good IMHO!
I have to trim the holes in the wing for the grille tabs a bit but otherwise the fitment is great (wing is aftermarket, grille is OEM Porsche).
#37
King of Cool
Can't wait to see what the body looks like at that point!!
Looks good. Mine's the same way, had to drill the holes.
#38
Decided to skip the filter box for now and just installed the cone filter.
Filter box needs some engineering for which I don't time right now. It is getting colder and darker here so not many possibilities to take her out on the track anymore.
But, it's ready now!!!! First test will be on friday evening.
#43
King of Cool
