G50-20 6 speed with LSD, priced to go.
Did a ROW MY96 trans swap (stock shorter gearing w/LSD) in my MY98 993 waaay back in 2000. The gearbox makes the loss of specific power output of the 3.6l at elevation (8,000ft) easier to take and when closer to normalized elevation levels the shorter gear ratios are simply a hoot to drive.
Just a thought: Could the seller identify a local Texas resource to validate the present condition of the trans? I would think this would assist with the sale.
It's priced as if it needs a rebuild, I'm 99.9% sure it is in excellent condition, I can open it and visually inspect but it will need new seals and new nuts if you want to do it properly, and few hours of work. I can open the LSD cover and take pictures of the ring and pinion as well as LSD. If someone is interested.
Straight up guy and well known in the racing circles in this area of the woods.
When we agreed friday that funds would be deposited on monday and I received your banking info
I was under the impression this is a done deal...
Am I under the wrong assumption? Bert
Thanks Cupcar for the tip, they go for more money even on this board, but I want somebody here to get the good deal.
Ok i see these time and date stamps can be misleading ..if you have any concerns about me being able to complete transaction just check my ebay ,same screenname as here and pelican and early registry,
let me know offline if there's something additional you want me to do, thanks Bert
