My 993 brethren, my faith is being sorely tested.
I do not remember your alternator problem - what is causing the issue that is repeating?
Not to compare, but you are having minor problems - I spent 18 months fighting Porsche to replace my Targa roof while the car was off the road, then did a total engine rebuild due to valve guide wear, replaced tons of parts, had the car painted end to end, had an accident that took the car off the road for 6 months because Porsche did not stock a part so I had to wait for enough orders worldwide for them to do a manufacturing run, and overall I spent about twice what the car is worth.
So what were my choices?
1 - Get another car, not Porsche. Believe me, that thought crossed my mind- I looked at Cooper S Works, STI's, a few others - but nothing compared to Porsche and the 993 series. I just love the cars and the community that goes with it.
2 - Declare the car a lemon, and sell it. Well, its weird, when the car was down or just screwing with me, I wanted to sell it - when it was fixed then I thought, gee with so much $$$ and time in this car, why sell - then it would break again. At the end, I had a talk with the car, and I told it if it screwed with me again in the next month, I am selling her - and she burped the roof system at week two so I sold her - NO regrets.
3 - Fix the car. This was my default mode, and you have to watch the patterns to see if the car is now a lemon (or Christine).
Cheers,
Mike
Cheers,
Mike
Seared
My alternator is original and has 258,000+ miles.
In my 4Runner.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Good luck getting the issues sorted - these cars are worth it.
Andreas
In my 4Runner.
Andreas
Ed I'll trade you my fuel tank woes...my car reeks of fuel on the inside. My wife won't even sit in "the Porsche" unless I get it fixed.
Just be thankful that you aren't spending $1k just to replace a fuel tank that shouldn't need replacing!!!![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Hang in there...
Hang in there...
RL Technical Advisor
We are seeing some bearing issues with Bosch-rebuilt alternators,...............
I may need to look into a better quality bearing than they are providing and do these here to control QC.
I had the owner of a gorgeous Diablo pull up next to me and give bow down to my niner. This sort of admiration happens almost every time I take it out. Take it to a good shop and work out the alternator problem. I just did similar for distributor which cost me a pretty penny but I have the backing of a good shop in case it goes bad again. Also you own a car that is rare and can be customized in so many ways to give you exactly what you're looking for without loosing any or little value and even gaining all as long as you keep mods within standards true to heritage. Another good reason to keep is you have the backing of a community of die hard loyalist around the world to help you. There are guys here that can tell you every nut and bolt on these cars.
Ed,
Is the alt. issue electrical or mechanical? If the issue is a recurring electrical, I have been told the battery to body ground strapcan cause issues. Over time it will lose a good connection to the frame. I replace mine and a lot of gremlins disappeared.
Then you also have the owner or shop that does not have that extra one or two pulley shims that they should have on hand resulting in excessive belt tension. The old calibrated thumb doesn't help either.
I marry my wife because I am sure (1) I love her, (2) I can grow old with her and (3) we can live happily everafter. However, question is I am only human. Now she is 28 and hot hot hot. When she turns 82, would she still be this hot hot hot to the beholder me? Answer is maybe not 100 but I must at least now foresee 70 to 80.
A good woman has the kind of charm that does not fade with time. So's a good car. A 993? Yes yes yes. A Civic? No no no.
Of course it will be some custom germany-bosch-only bearing no longer available except for secret sources in german beer houses.....
hey man, if you've reached the end of your rope, sell it, try something else for a while, and then come back if you need to. They made enough of these things that you'll always find another.
If its just frustration talking, it will pass, but if you begin to resent the car for the repair costs, its not worth it to keep it.
After all, its just a car.
