19X10.5 ET 57MM On Narrow Body 993???
As the title states above. What tire setup would you recommend for this setup. Would a 295 fit or rub on a lowered car? If so what size tire would you recommend.
the rim will barely work, but you may have oil line issues on the right side (and rolled fenders will be needed). 65mm offset would be better to avoid rubbing the outside fender. Also depends on how much camber you run on the back. 295 is actually not the better tire size to run on the 993. 285 would work better. As example the Hoosier R6s when I ran them were the same actual measured width in the 285/295, but the 295 was taller. Originally there were issues with the 285 cording since it was intended for front tire use on GT racing cars like the vette and viper. That was cleared up awhile ago.
I can't vouch for the outside clearance though but it could work. Trial and error.
GL
ignoring tires, a 10.5ET57 w/ the same flange width as a Speedline(.5"/side) sits 14.35mm closer to the lips and sits 1.65mm further from the inner chassis
I'd say it's not gonna be a pretty fit.
anecdotally I used 10ET56 at RoW M030 height they are fine, at Cup car height the drivers side 265/35 x18 will kiss rolled lips on bumps
Correct, but a 295 tire (taller), toe setting and camber it's going to be close. Non solid bushing and increased suspension movement all factor in. Even with the 65ET it is really close on a 10" rim and a 285. It would require a trial fit to be sure. I have a set of NB Fikse rims 10.5 width and 59 ET and they worked, but barely. When the suspension went to full race it was more tolerant.
