43mm rear offset , 10" wheel in NB?
I run 10.5" rears on ET56. Assume this is the equivalent of an ET58 on a 10" rim. I have suspension lowere ROW Mo30m-15mm - so similar to RS + 10mm. I did have to roll the rear fenders after experiencing rubbing on high speed "dips" and joins in the road.
I use 265 Bridgestone Potenza RE11.
There is now way you can manage ET43. You cant really even manage ET 50 or 56 on a NB with 275-285 tires IMHO without significant rolling.
Cheers
M
Cheers
M
A 10.5" with +56 is closer to a 10" with +49.
Oops you are correct. Approx ET50 on 10". You really are not going to get any more agressive than this without panel modification. I chose a 265 rear with a very curved edge pofile to help with eliminating the rubbing. I honestly could probably have got away with not rolling if I had have had another 2mm to play with - it was really that close. I have some H&R springs Id like to fit which will lower the car to RS spec height but Im really reluctant as I think I may have an undrivable car. Other options due to three piece design is to change the outer forged rim pieces and bring down to 10" with ET61 which is a very safe option but does reduce the rear "dish" which was half the attraction of these wheels.....
Good luck.
Good luck.
Bill, I was thinking about this and realized I messed up my math. Here are all the numbers.
CCW Classic wheels
Front
Bead width = 9"
Total width (measured) = 10"
Backspace (measured) = 7" = 177.8cm
Frontspace = 76.2cm
Offset = ET51
Toyo T1R 245/35R18
Rear
Bead width = 10.5"
Total width (measured) = 11.5"
Backspace (measured) = 8" = 203.2cm
Frontspace = 88.9cm
Offset = ET57
Toyo T1R 285/30R18
Please let me know if that makes sense. Sorry about my confusion.
CCW Classic wheels
Front
Bead width = 9"
Frontspace = 76.2cm
Offset = ET51
Toyo T1R 245/35R18
Rear
Bead width = 10.5"
Frontspace = 88.9cm
Offset = ET57
Toyo T1R 285/30R18
CCW Classic wheels
Front
Bead width = 9"
Frontspace = 76.2cm
Offset = ET51
Toyo T1R 245/35R18
Rear
Bead width = 10.5"
Frontspace = 88.9cm
Offset = ET57
Toyo T1R 285/30R18
CCW Classic wheels
Front
Bead width = 9"
Frontspace = 76.2cm
Offset = ET51
Toyo T1R 245/35R18
Rear
Bead width = 10.5"
Frontspace = 88.9cm
Offset = ET57
Toyo T1R 285/30R18
Can I get an idea of the fender height you are running & rear camber if possible?
On the front I ran a similar setup so I know it works at really low ride heights
Got any pics?
Bill,
My ride height (w/ MY02 wheels and 265/35 & 245/40) is 25.5" in the front and 25.0" in the rear
Front camber = -1.5deg & -1.7deg
Rear camber = -2.1deg & -2.1deg
Pics w/ the CCW wheels...
![](http://i4.photobucket.com/albums/y148/plexicrunch/Porsche%20993/IMG_6234.jpg)
![](http://i4.photobucket.com/albums/y148/plexicrunch/Porsche%20993/IMG_6236.jpg)
thanks!, the car looks great. So have you been running it w/ the ccw wheels? any issues?
^The PO ran it for a year or so with the CCW/Toyo setup, and I ran it for another year until the rear tires wore out. That's when I put the current MY02s and Bridgestone RE760 tires on. Absolutely no issues with either setup.
CCW Classic wheels
Front
Bead width = 9"
Frontspace = 76.2cm
Offset = ET51
Toyo T1R 245/35R18
Rear
Bead width = 10.5"
Frontspace = 88.9cm
Offset = ET57
Toyo T1R 285/30R18
CCW Classic wheels
Front
Bead width = 9"
Frontspace = 76.2cm
Offset = ET51
Toyo T1R 245/35R18
Rear
Bead width = 10.5"
Frontspace = 88.9cm
Offset = ET57
Toyo T1R 285/30R18
I'm looking to get a 993 soon and would like to know if the bead width listed on the first quoted post is the wheel width with the following specs. --> F - 9x18 E.T. 51 and R - 10.5x18 E.T. 57 with the 245/35 and 285/30 sized tires?
If so, that's the setup you ran on the yellow 993 below?
That's exactly the look I'm going for. I'm a huge sucker for the CCW Classics with the proper amount of rubber.
Unless you ran with a lot of negative camber, rolled your fenders, AND were willing to do a lot of stretch with a thinner tire, it ain't gonna happen. Even then, I would doubt it would work without rubbing. I recently installed 10X18 BBS LMs and reverse mounted the centers. The offset went from 65 to ~49 and I had rubbing issues, but my fenders were not rolled. It was too much of a hassle so I reverted to the conventional mounting of the centers.
