993 Forum 1995-1998
engine under tray
Old 07-02-2012, 01:26 PM
  #31
Cactus
Noodle Jr.
Cactus's Avatar
Originally Posted by NC TRACKRAT
Next thing you know, some wise-azz will start a "What Oil Do You Use" thread! (Please Nooooooooooo!)
Then when we get bored with that we can start the "What is the fascination with the RSD?" thread
Old 07-02-2012, 01:27 PM
  #32
IXLR8
IXLR8's Avatar
Originally Posted by Greg Labadie
There was a guy in Canada that was going to do some cylinder head temps once summer arrived (last summer). Any news on the tests?
None yet as I've had too much on my plate to get around to doing so. Sorry!
But I'm looking forward to collecting the data, having been in the metrology standards business for years. Till then I would not make a comment as to whether the engine runs hotter or not with the engine tray on.
This topic has been discussed long before I even got on this forum. Amazingly none has ever produced any hard numbers where a thermocouple was used directly on the cylinder head. I don't put much stock using an optical thermometer from Harbor Freight....kind of hard to look at when in motion under load.
All the best from sunny Italy where the food and wine is great and the roads are twisty.
Old 07-02-2012, 01:44 PM
  #33
Van1
Van1's Avatar
You guys are going to be sorry when 30 years from now folks are restoring 993s like 356s are being restored today and the engine tray is that last final piece that a restorer needs to make their car concours perfect. They'll bring big money someday!
Quite honestly, I could care less about cylinder temps with or without the tray. Track weekends would be a PITA trying to lift the rear via engine case to change brake pads with the tray installed. And if Steve W ways leave it off, thats good enough for me.
Old 07-02-2012, 03:03 PM
  #34
goofballdeluxe
goofballdeluxe's Avatar
Originally Posted by inkatouring
If I had it on, I wouldn't get to listen to the metalic scrapping on the ground every time the orange hoses on the heat exchangers self-destructs....
No one ever seems to mention that there is a real risk to engine damage running without an engine tray, especially if your car has been lowered, as mine has.
Running with my engine tray off, my heat exchangers caught on a driveway as I was backing out of a driveway, and tore off and destroyed my left side heat exchanger in the process. This only happened because I was running without an engine tray.
A new heat exchanger will set you back a few hundred bucks. Luckily I found a Rennlister who had an extra one laying around.
Needless to say, I'm running WITH an engine tray now.
Old 07-02-2012, 03:22 PM
  #35
Quadcammer
Quadcammer's Avatar
Received 1,416 Likes on 818 Posts
heat exchanger or flapper box
Old 07-02-2012, 03:42 PM
  #36
goofballdeluxe
Oops, sorry, flapper box.
Old 07-03-2012, 12:33 AM
  #37
chaoscreature
chaoscreature's Avatar
BobT993,
That is fantastic.
Just curious, do you run it with the large hole/gap in the back or is a filler piece back there?
Thanks!
Old 07-03-2012, 08:54 AM
  #38
bobt993
bobt993's Avatar
Originally Posted by chaoscreature
BobT993,
That is fantastic.
Thanks!
Back was screened in during final fitment (you want to separate the engine air flow from the underbody is possible only having them join at the very back at the same pressure/velocity). Helps with attached flow. I am doing some more test on a medium speed track in two weeks while we monitor cyl temp using the motec data. I added several vents and next is two 4inch fans with naca ducts. Headers are SCargo. The entire trays removes in 5mins or less. There are 3 sections all the way to the front splitter.
Old 07-03-2012, 11:44 AM
  #39
aribop
aribop's Avatar
This guy thinks they are valuable now
http://www.ebay.com/itm/Porsche-OEM-...a91920&vxp=mtr
Smoking some serious crack!
Old 07-03-2012, 11:52 AM
  #40
Opo
Opo's Avatar
Only in TEXAS!!
Old 07-03-2012, 12:03 PM
  #41
Mark in Baltimore
Mark in Baltimore's Avatar
That is so f*cking hardcore.
Old 07-03-2012, 02:22 PM
  #42
bobt993
bobt993's Avatar
^^^^^^^^^^ Well, considering you have to run a 1:18 at Summit to be competitive in GTS3 (which is similar hp/wght ratio to PCA H class), you need to start working on aero for GT class and NASA GTS class. This is a long project, but I should have some good racing results near end of the summer. Mark, hope to catch up to you and Jim E at Summit this year.
Old 07-07-2012, 08:05 AM
  #43
IXLR8
IXLR8's Avatar
BTW, where did the factory Porsche team lift the rear of their 993s back in the day...because the owner's manual tells you not to use the engine as a lifting point.
Old 07-07-2012, 01:12 PM
  #44
pp000830
pp000830's Avatar
Received 1,535 Likes on 1,084 Posts
Engine tray in attic.
Transmission section cover disappeared, probably forgotten by a service technician.
Old 07-07-2012, 05:03 PM
  #45
Ed Hughes
Ed Hughes's Avatar
How many tens of thousands of times have 911-993's been jacked up from the engine?
Quick Reply: engine under tray
