993 Forum 1995-1998
Dansk WB wide oval tips
Old 07-06-2012, 02:31 AM
Testdr
Testdr's Avatar
Old 07-06-2012, 04:21 AM
911PERVY
911PERVY's Avatar
Looking good, can we see a view from behind please? Agree they could do with a spray of black inside, Dansk used to finish them like this a few years ago but seem to have stopped this now, must save them $2 a pair!
Old 07-06-2012, 07:41 AM
Testdr
Testdr's Avatar
Sprayed and test fitted. I need to get longer bolts tmr since the flange on the dansk exhaust tips are longer and the clamp doesnt close as fully as with the stock tips.
Top down view
Compared to stock tips.
So far happy with the results.
Old 07-06-2012, 10:20 AM
CarreraX
CarreraX's Avatar
Just an FYI, if you loosen the complete muffler, you can adjust the muffler and tips to that the angle on the tips matches the angle on the bumpercover. I had to do this with my Ruf tips to get them perfect. Also had to rotate them to get them right. At the end they turned out perfect. Just takes some time.
Old 07-06-2012, 10:22 AM
911PERVY
911PERVY's Avatar
Yes Mark, it sure takes time! I took ages to get mine so Im happy ish with them, they are still not 100%, mufflers and cats need a tweek I think!
Old 07-06-2012, 10:26 AM
CarreraX
CarreraX's Avatar
I just couldnt get mine to look right when looking down from the top. One stuck out more and the angle didnt match the bumper. I finally loosened the muffler and kept moving things and now they are perfect. FYI, I had a set of FD ones that were awesome but when I stumbled on the Ruf ones I couldnt pass them up. Sorry for the huge picture.
Old 07-06-2012, 10:45 AM
JPP
JPP's Avatar
Originally Posted by Testdr
Just received them via Fedex express from UK, thanks Matthew
Nice! Thanks for following up, I know this will be an alternative for folks looking for a rolled edge tip. Nice deck btw ... is that Teak?
Quick Reply: Dansk WB wide oval tips
