MY02 wheels rub rear caliper?
Seared
Thanks for all of the responses. The 5mm spacers that I installed last night provide more than enough clearance - I'll leave them on for now.
The interference is very, very fine (only on the driver's side) and would have left a slight rub mark had I not noticed that the wheel touched. Here is the area in question (pic of my pre-refreshed caliper):
Andreas
Andreas
Bizarre. I've never noticed how little space there is at that spot until this thread made me look. I have powder coated calipers and MY02's and although the clearance is tight (<1/4") it hasn't rubbed. You'll notice in the pictures that my caliper decals have held up nicely (thanks again).
For me a little too close, Big Reds or Spacers should be in your future.....
But seriously - I think the pictures make it look closer than it really is. I've run the car a whole season with it like that without a single problem.
Seared
My car is at ROW (or a bit lower) height with Bilstein HDs and M030 coils.
Andreas
It's funny that some MY02 5spokes seem to have the issue and others don't, I wonder if it's simply oe BBS vs aftermarket or something else
When I bought my car it came w/ the small stock brakes and BBS MY02 5 spoke wheels and had no issues.
Some folks put them on the front only, helps with turn in on track orientated cars, so they say.
Seared
I wonder if there's a slight casting or machining variance between the left & right side hub/bearing carriers? The wheels are brand-spankin' new BBS MY02 wheels with similar date codes (purchased from Sunset).
A few months ago I mounted a damaged 10x18 ET65 MY02 on the left rear hub to see if I liked the look. For whatever reason, I turned the wheel slightly and saw that it left a rub mark on the very caliper in question. At the time I chalked it up to a bent wheel (although I had a difficult time believing the spoke material local to the hub face was out of whack).
So, the interference, while very slight, is real. I'm perfectly fine running the 5mm spacers.
Andreas
Andreas
I took a closer look with better light, and there is a tiny rub mark on both rear calipers, in exactly the location Andreas indicated in his picture. My wheels are genuine Porsche/BBS. Car is a 95 NB, original US (SUV) ride height.
It appears that the clearance issue may not be all spokes, but just one or two...next time I have the car up, I'll take a look at any marks on the back side of the wheels.
I'm wondering if there was any play at all when you mounted your refreshed calipers, before you tightened them down. It wouldn't take much one way or the other for the rubbing to occur - seeing as how little room I have with no rubbing. Just a thought.
Seared
Andreas
IIRC the hub offsets on the brake rotors are different, could this be the issue? Forget if it was the front or rear rotors but there was a difference.
