993 Forum 1995-1998
Wevos installed. Impressions!!
Old Jun 19, 2012 | 01:14 AM
ginch's Avatar
ginch
Default Wevos installed. Impressions!!
So I finally got around to getting my Black pillow wevos installed. I replaced them due to the fact the drivers side mount was blown. Impressions so far. Nothing really changed. I noticed no real difference in vibration within the car. The handling I guess feels more planted but nothing overly noticable. It does sound as thought the motor is louder though. Is it just my imagination?
Old Jun 19, 2012 | 07:21 AM
Cactus's Avatar
Cactus
Noodle Jr.
I just did the RS mounts and I noticed the car shaking a bit at idle.
Old Jun 19, 2012 | 10:38 AM
Quadcammer's Avatar
Quadcammer
same, its not an earthshattering difference by any stretch
Old Jun 19, 2012 | 11:18 AM
trophy's Avatar
trophy
Did you notice a change in shifter feel? This is where I noticed it the most change, the little bit of vagueness the shifter had before certainly disappeared.
Old Jun 19, 2012 | 12:14 PM
Michaelc's Avatar
Michaelc
My mounts were shot, new RS mounts tightened everything up. More vibration for me at idle.
Old Jun 19, 2012 | 01:07 PM
ginch's Avatar
ginch
Hey Steven,
No change in shifter feel at all. Again really the most noticable change was the noise the motor made. It seems like its rougher sounding but that might just be in my head!
Derek
Old Jun 19, 2012 | 06:20 PM
P-daddy's Avatar
P-daddy
How long did this DIY take?
Old Jun 19, 2012 | 07:17 PM
Cactus's Avatar
Cactus
Noodle Jr.
I'm thinking it will take longer to get the car on stands then it will to change the motor mounts.
Old Jun 19, 2012 | 07:51 PM
Michaelc's Avatar
Michaelc
For me it was 20 minutes per side, going very slow and taking my time so as to not strip out any bolts or make any mistakes. Very easy DIY, the only challenging part was cleaning up the nasty goop that came out of the old motor mounts. both mine were cracked and leaked goop all over the garage floor.
Old Jun 23, 2012 | 11:24 AM
ginch's Avatar
ginch
Can anyone comment on whether these mounts will cause my engine to sound a lot more rough? Almost seems like the motor is knocking now. Don't really hear it when the windows are down but when they are up the engine makes a terrible racket!!!
Old Jun 23, 2012 | 11:31 AM
Testdr's Avatar
Testdr
Just installed the blacks on my C4S, together with reinforced engine carrier. Definitely a difference. Rougher, YES. Feel it in your bum, your hands on the wheel but passenger probably not so much. More obvious with windows up... you can hear more of the engine's little noises as well. I like it alot, but some will not. I had fabspeed supercups before so my tolerance for noise is higher.
Old Jun 23, 2012 | 11:34 AM
Falcondrivr's Avatar
Falcondrivr
They transfer more mechanical vibrations from the engine to the unibody, and so more reaches the cabin. The ac compressor sounds a bit like a supercharger....
Old Jun 23, 2012 | 01:41 PM
ginch's Avatar
ginch
Well I can't stand it! It makes it sound as though the car has a major engine knock. Going to have to buy a set of stock mounts!
Old Jun 23, 2012 | 05:28 PM
levtron's Avatar
levtron
Thats too bad. I did the Blue ones from Wevo, and it changed the car for AX, major difference in the handling. On the street it just feels a little tighter in the back end. More planted. I also did a LWF and GT3 clutch/pressuse plate, so mine is louder, but not just from the Wevo's ;-)
I recommend the Wevo's.. Especially if you AX... Your milage may vary...
Old Jun 23, 2012 | 09:03 PM
jnoble79's Avatar
jnoble79
Originally Posted by Falcondrivr
\. The ac compressor sounds a bit like a supercharger....
hahaha!!! Thats an awesome description.
