993 Forum 1995-1998
DIY remove the steering wheel center cover
Old 06-11-2012 | 10:09 PM
peter y.s pang's Avatar
peter y.s pang
Default DIY remove the steering wheel center cover
would like to know the procedure of remove the steering wheel center cover.
Old 06-11-2012 | 10:19 PM
Mike J's Avatar
Mike J
Two torx screws .... you can feel them on the backside of the steering wheel. Turn the wheel to allow space for your screwdriver. I cannot remember the size off hand, but its quite standard. Take them out, and then the airbag is loose.
If you intend to change the airbag or unhook it, its recommended to disconnect the battery and wait for 10 minutes at least - just to make sure that any potential capacitive storage of power has bled off (very conservative recommendation).
Why are you taking it off?
cheers,
Mike
Old 06-11-2012 | 11:43 PM
peter y.s pang
seems the horn is short circuit. it loud automatic when i turn the steering wheel.
Old 06-12-2012 | 05:26 AM
911PERVY's Avatar
911PERVY
Common problem, search "air bag frame"
Old 06-12-2012 | 12:58 PM
bugs's Avatar
bugs
Hi Peter,
As what Mike has said there are two torx screws at the back of the steering wheel. I fixed my retaining frame problem two years ago. There are tonnes of info here and the people here are extremely helpful. Do give it a go. Remember if I can do it so can you : )
All you'll need is a long torx drive and a little patience. Here's some crappy photos on the tool and torx screw.
Old 06-13-2012 | 01:06 AM
peter y.s pang
Thanks a lot , Stanley. by the way, you have nice wheel on your 993. i wish to get 1 set for my 993 as well.
Old 06-14-2012 | 05:47 AM
bugs's Avatar
bugs
Thanks, Peter
I have the original 17" targa wheels on my targa. Locally, they are very affordable 2nd hand wheels (I guess most would swap them out to 18" wheels). You can keep an eye on the local car website (ie, 28car.com) they come up for grabs once in a while.
With 2 kids and a dog, I don't drive my targa as much as I would like to and became an addicted reader. I'm just amazed, and occasionally in awe, at the work of the DIY fellows here. Anyway you are welcome to PM me.
Cheers, enjoy your 993.
Quick Reply: DIY remove the steering wheel center cover
