993 Forum 1995-1998
Installed RS Mounts today. Impressions:
Old 05-21-2012 | 01:52 PM
FisterD's Avatar
FisterD
Originally Posted by Quadcammer
not sure why people go RS over the wevos, but glad you like them.
We have had 2 cars that had problems with interior vibration/resonance after installing the Wevos. Switched out to RS mounts and it went away. Not sure what factors contributed to this, but we prefer the RS moints to avoid this issue with other clients.
That being said, Wevo has a nice product and many people use them with success.
Old 05-21-2012 | 02:48 PM
1pcarnut's Avatar
1pcarnut
Exactly, went with the RS, didn't want any chance of some of the NVH that has been mentioned with the Wevos. YMMV
Old 05-21-2012 | 02:51 PM
vincer77's Avatar
vincer77
When I installed the RS mounts, I also felt that the rear end was more controllable with less lateral movement. I noticed a bit more vibration/noise, but have gotten used to it.
The mounts I took out were most likely original but looked to be in good shape with no leaks.
I did find clutch feel was better, but my shifting has become clunky - almost as if clutch was not completely disengaged - but I think it is a worn rubber bushing in shifter. Will replace when I do Goldenrod.
I also noted that front end "shimmy" has become noticeable so will be installing Walrod bushings in the near future.
Old 05-21-2012 | 02:59 PM
nile13's Avatar
nile13
Originally Posted by Mike J
...in good shape - no leaks, appeared to be stiff, etc. Or it could be that my butt is not sensitive enough, not sure what it is, but I was disappointed.
I dunno. All I can tell you, don't read this wile watching Pornucopia on HBO.
Old 05-21-2012 | 03:16 PM
vincer77's Avatar
vincer77
BTW, I chose RS over WEVO simply because they were Porsche. No other good or technical reason.
Old 05-21-2012 | 04:27 PM
helmet993's Avatar
helmet993
My only reason was they are OEM parts.
Old 05-22-2012 | 08:14 PM
helmet993's Avatar
helmet993
For reference this is what my old mounts looked like...no leaking but they were definitely not performing to design intent...
Old 05-22-2012 | 08:39 PM
cgfen's Avatar
cgfen
Originally Posted by pstraub
Thanks for the great review, I am planning on installing RS mounts this summer when I do my 60K service
keep your eyes out for my for sale advert.
I have put RS mounts in two of my cars so far, and in both cases, noticed very little impact or difference.
Mike
other than increased NVH, I agree
I've decided i don't want to get used to it
so
soon to be for sale
lightly used, ~ 1200 miles of use on dry So. Cal roads.
2 RS mounts P/N 96437504381
2 bolts P/N 90008203002
2 engine mount washers P/N 90130531100
4 washers P/N 99902507402
4 washers P/N 99902513402
everything you need to install the RS mounts except the 4 bolts that hold the "tops" down.
$310 + shipping from 92009
Hi
not yet for sale due to pending trade with a local friend.
if it falls through, i will post F/S
Craig
Old 05-22-2012 | 10:08 PM
vincer77's Avatar
vincer77
So you going to C2 or C4 mounts?
Old 05-22-2012 | 10:22 PM
Ed Hughes's Avatar
Ed Hughes
That much difference?
so
soon to be for sale
Craig
Old 05-22-2012 | 10:24 PM
Magdaddy's Avatar
Magdaddy
Originally Posted by Cactus
RS motor mounts and Walrod bushings going in this Friday.....excited!
fresh alignmet also???
She'll feel brand new, money well spent
Old 05-22-2012 | 11:30 PM
kjr914's Avatar
kjr914
Craig's just a very sensitive individual....
(Hope he doesn't hear us talking about him....)
Actually, he's been on a "back to stock" kick for his car, so it might be part of it as well.
I did notice the NVH increase as well when I did mine, since I often use bluetooth in the car. BUT it wasn't horrible and I got used to it. I think my DAS bar install causes MUCH more noise, since its tied directly to the body and brings all that noise into the cabin. But who cares? Right pedal to the floor fixes any sound issues!
Old 05-23-2012 | 12:09 AM
Ed Hughes's Avatar
Ed Hughes
How do Wevo softs compare to RS? I'm kind of motivated to change my 18 YO mounts this summer, but don't want to sell stock to buy stock bits. I was thinking RS may be the way to go.....
PS-the wheels are with Nathan at Velvet Touch.
Old 05-23-2012 | 03:42 AM
Cupcar's Avatar
Cupcar
I think a lot plays into the decision here. Mostly how hard do you really drive the car and whether you listen to a sound system and are sensitive or not to mechanical noise.
If a sound system is part of your driving enjoyment and you are not driving the car full throttle a lot or on a track, then probably stock mounts are what you want. These are hydraulic isolation units that isolate noise and vibration, but allow the engine to move around enough to affect the shifter and throttle response in hard onand off full throttle use.
If you want a bit more precision in the shift gate and autocross or track the car once in a while, but have a radio and don't want much more interior noise and need better throttle steer get the RS or Wevo which have a little rubber in them but much less engine motion and some noise isolation.
If you have no radio, like the sound of mechanical things, have removed the sound deadening anyway, have a light flywheel and louder exhaust you won't notice much more noise going to solid mounts from RS (I have done this), but you will notice the other benefits of better throttle response and shift pattern stability.
Old 05-23-2012 | 05:22 AM
David in LA's Avatar
David in LA
Wevo's are stiffer than the RS...I think it a qualitative rather than quantitative thing. One thing that may (or may not) matter to you, is that when going with Wevo, most shops (incl IIRC Rennsport) will recommend that you strengthen the engine carrier unless the car is a Turbo. Most here will opine that is not necessary esp if you don't track the car and will say they have never had an issue, but if you ask a shop they will tend to be conservative and recommend you do it. A broken engine carrier at speed can be nasty....there was someone either here or on the 964 board that had a broken carrier on a stock car with factory mounts. Also, if you see a stock carrier in person, it is surprisingly thin
