Clutch Slave & Master Cylinder Replacement
But the pics and brief explanations give those about to replace those items a heads up as to what to expect before swinging a wrench.
Maybe I'll get to a more detailed step-by-step DIY one day. At the moment, p-car workshop is a good resource; although I've made a couple of additions and corrections there.
nice write up. I need to do this soon. my pedal is starting to hang up in the last little bit of travel
I bought my 993 with the annoying and well known "grawk" sound that most of us are familiar with when activating the clutch. Worse yet was the uneven, almost stepped action when engaging the clutch making smooth starts more difficult. A simple fix which did not alter my buying decision.
This past winter I finally got around to replacing the necessary parts. I chose to go with OEM Porsche parts sourced from Sunset.
Along with a new clutch hydraulic hose and a complete pedal assembly rebuild (cleaning, new pedal bushings and re-greasing), clutch action is whisper quiet and ultra smooth. A highly recommended DIY with results that will put a smile on your face.
Brake fluid used was ATE Super Blue and flushing/bleeding was performed with the aid of a Motive Products Power Bleeder, both sourced from Pelican Parts. I modified my Power Bleeder to make using it in the "dry method" easier.
Not a DIY set of instructions, but plenty of pics with some tips.
Back in 2010, the clutch slave cylinder was $98 and the clutch master cylinder was $88 from Sunset. The clutch pedal lever was $71.
In 2012: $13.62 for two clutch pedal bushings and $14.56 for two brake pedal bushings.
Check the Auto Atlanta site for current list prices.
Edited to add: I guess I never updated this. I'm sorry to say but the "whisper quiet" aspect may have been the case in the garage after the parts were replaced, but once the car was back on the road after a few kilometers, the typical "grawk" returned. So as initially thought but hoped it was not, the pressure plate and/or clutch release bearing fork bushings and shaft are the only other possibilities. Which is one of the reasons why my 993 has been on the lift for a while now.
- the plastic bushings on the clutch fork to clutch fork shaft
- the roller bearings on the clutch fork shaft
- the metal to metal interface between the clutch fork and the throwout bearing
- the clutch tube where the throwout bearing rides along
- the pivots on the pressure plate spring
To me, the noise sounds higher up on the transmission so I am not sure where it comes from, but it sure feels like clutch fork related.
Looking at the typical wear points when doing a clutch, the plastic bushings on the clutch fork typically show little wear (likely because the clutch fork shaft is on roller bearings) so I doubt if that is it. My feeling is its either the pin on the top of the clutch fork (and when used, the pressure displaces the grease and it squeaks again) or the forks on the through bearing ...
Cheers,
Mike
Mike, my Honda CR-V was making the same noise when it got into the 12th or 13th year. I even lubed the pivot ball the release fork ran up against and the clutch master and slave cylinders were relatively new. I suspect the same issue; the pressure plate.
After my 993 passed its PPI, I was driving it back to the dealer when the clutch pedal went all the way to the floor and stayed there. Pumping it got it to work, and the dealer flushed the system. I thought maybe the master or slave cylinder needed replacing, but some 2000 miles later the clutch continues to work smoothly.
ChuckJ
When bleeding the clutch slave, for some reason (probably because the fluid does not circulate) it bleeds some very ugly/sludge-like fluid, and if it get too nasty, I'm thinking it could cause the slave to stick, and the pedal to stay on the floor? My theory...
Personally, I have never had my pedal go to the floor, except when I absent-mindedly introduced air into the system; and I wasn't on the road at the time. Actually, I don't see how the pedal dropping to the floor is feasible with a properly working clutch at one moment, and then BAM! Pedal to the floor. This being said, I'll stick (no pun intended) with my theory on the nasty sludge-like fluid that initially bled from the slave.
I now bleed the slave every other year when I do a brake fluid refresh on all 4 corners; with the fifth corner being the clutch slave. The logic is, if you have the car on stands and wheels off, and you're bleeding the brakes; might as well hit the clutch slave while you're up there.
Doing a slave bleed every other year does not produce the ugly fluid that I initially saw.
If you track the car, them more often I would think. Bi-annually, maybe? Beginning and again mid-season.
P.S.
Alex, am I hallucinating, or is the link to your DIY now gone?![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
TIA,
Paul
P.S.
TIA,
Paul
Cheers,
Mike
I can understand metal fatigue and how a spring can decay with use, but I have never seen one so bad that it impacts the feel of the pedal - but then again, it might be doing that and i just never thought that could be a problem area! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Yes, its the spring assist in the pedal cluster that he is talking about.
Cheers,
Mike
Cheers,
Mike
