Clutch Slave & Master Cylinder Replacement
I bought my 993 with the annoying and well known "grawk" sound that most of us are familiar with when activating the clutch. Worse yet was the uneven, almost stepped action when engaging the clutch making smooth starts more difficult. A simple fix which did not alter my buying decision.
This past winter I finally got around to replacing the necessary parts. I chose to go with OEM Porsche parts sourced from Sunset.
Along with a new clutch hydraulic hose and a complete pedal assembly rebuild (cleaning, new pedal bushings and re-greasing), clutch action is whisper quiet and ultra smooth. A highly recommended DIY with results that will put a smile on your face.
Brake fluid used was ATE Super Blue and flushing/bleeding was performed with the aid of a Motive Products Power Bleeder, both sourced from Pelican Parts. I modified my Power Bleeder to make using it in the "dry method" easier.
Not a DIY set of instructions, but plenty of pics with some tips.
mine is at the "grawk" stage, but with no difference in pedal throw. Early in the season it is noiser, than after repeated use. It is my DD afterall.
The pedal bushing rebuild is definately in my future. For now, considering the occasional noise, I find that I can eliminate that annoying "grawk" completely...by simply increasing pressure on the Fister Stage III pedal on driver right.![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Thanks for the write up Alex, it's a beauty.
Awesome Alex!!!
I have replaced the Master Slave Cylinder a few years ago but need to get back in and do the pedal rebuild and the Clutch Slave cylinder - nice project for the next winter.
I will reference your DIY.
btw - what camera used?
Canon S95. It replaced my Olympus C-5060 which I still have.
Whatever I buy needs to have a wide angle, down to at least 28 optical. And it needs to be compact since I am on the road for 5 to 6 weeks in a row on my motorcycle while on tour in the Alps. There is nothing like an SLR, but by the time I'd bring a few lenses, my top case on the motorcycle would be full.
Considering its size and small lens, its not bad, and we all know what makes a great camera...its all in the lens, so I can only expect so much.
Many suggest flushing the hydraulic fluid which I did back in the summer of 2010 hoping to avoid having to replace all the bits I just did. Unfortunately, new hydraulic fluid didn't do the trick.
What I did find in my clutch slave cylinder after I took it apart was a lot of black creamy substance along with the hydraulic fluid. In comparison, the clutch master cylinder was as clean as can be. I'm wondering if the black creamy substance in the clutch slave cylinder was due to deterioration of the attached hydraulic hose that is immediately upstream. By the way, the piston and bore of the old clutch slave cylinder looked new. Go figure!
Alex,
In addition to the nasty "grawking" noise during clutch travel, how often did the pedal hang on the way back up? Mine hangs once in a while during the last inch of travel. I haven't noticed any more ever since I performed the complete brake/clutch system flush 3 weeks ago. Still, it doesn't mean the hanging issue won't return. I will definitely keep this thread for next winter DIY. Thanks
Nam
Nam
Many suggest flushing the hydraulic fluid...IXLR8
I think the grawk will return when our weather gets hotter.
Considering its size and small lens, it's not bad...IXLR8
After my 993 passed its PPI, I was driving it back to the dealer when the clutch pedal went all the way to the floor and stayed there. Pumping it got it to work, and the dealer flushed the system. I thought maybe the master or slave cylinder needed replacing, but some 2000 miles later the clutch continues to work smoothly.
Super write-up and pictures, Alex. I always enjoy your technical posts--extremely detailed and well-written. You are an asset to this forum.
