dash rattle
dash rattle
I had a loud dash rattle and after some searching, ended up fixing it by tightening the 10mm bolt behind the ash tray housing. However, my fix seems to be shortlived. I usually end up loosening and retightening this bolt once every couple of months due to the rattle coming back. Is there any longer term solution?
Thanks.
Thanks.
I dont want to end up welding this bolt in there because its not exactly loosening up right now...when I go to readjust, it is still very tight. Its not like its backing out a lot, so loctite might affect my ability to loosen and retighten in the future, dont you think?
Thanks.
Thanks.
lock washer might be a good next step...thanks for the idea.
dash rattle
most dash rattle is the lock lever behind the glove box **** ( screw backs off)
disassemble grease lock tite on
go for a drive
goggle the item I found it
Stephen
go for a drive
Stephen
If the bolt isn't actually loosening, I'm not sure how Loctite or a lock washer will resolve the issue. Also, is it a plastic-sounding rattle, metallic-sounding rattle or what? It almost sounds like something behind the ash tray housing needs to be padded to prevent two objects from hitting one another.
