993 Forum 1995-1998
993 bad years?
Old 04-09-2012, 03:07 PM
goofballdeluxe
goofballdeluxe's Avatar
The only "bad years" are the years you didn't own a 993
Old 04-09-2012, 03:37 PM
Bill Verburg
Bill Verburg's Avatar
Originally Posted by JPP
Bill ... you know none of us are as organized as you with information .. well, I guess I'll speak for myself here .. I'll have to backtrack and see if I have a copy from my Cab's PPI, I can't remember if the shop actually had it or he showed it to me online. So, there was one on the '95's as well? ..
This is the only one related to the heads that I have
Old 04-09-2012, 03:53 PM
levtron
levtron's Avatar
LOL
Old 04-09-2012, 04:32 PM
JPP
JPP's Avatar
Hi Bill ... ok, of course, I couldn't find a paper copy .. but just for you I called the shop and asked about it and they said it was a failure due to defective cylinder head studs .. I guess they would work loose out of the block .. and that caused leaking and eventually failure. The referred me to this:
Old 04-09-2012, 04:46 PM
Bill Verburg
Yes, I have that one but can't find anything about weeping headgaskets on a 993
993 issues I have TSBs for
engine mounts
cam timing
cam bolts
oil return tube
head torque(posted above)
oil fill bellows
oil filter
oil drain plug
fan belt
heat pipe
alt pulley
cam housing
crankcases
vacuum lines
wiring harness
valve lifters
knock sensors
piston spray
Old 04-09-2012, 06:38 PM
JPP
JPP's Avatar
Yeah, I think were getting hung up on semantics here. The results of these studs allowing the head to come loose cause the head gasket to fail and oil to leak out at the cylinder base .. it's not a 'weeping' problem, it's a leaking problem ..
Anyway, TSB out in November '96 so this would be MY '97 and on which are the physical cars I've seen ..
Old 04-09-2012, 06:44 PM
JPP
JPP's Avatar
^^^ I should edit that and say it probably could be ANY engine on any year that used those Crankcase studs ...
Old 04-25-2012, 02:00 PM
The Brewmeister
The Brewmeister's Avatar
engine mounts
cam timing
cam bolts
oil return tube
oil fill bellows
oil filter
oil drain plug
fan belt
heat pipe
alt pulley
cam housing
crankcases
vacuum lines
wiring harness
valve lifters
knock sensors
piston spray
What does the TSB on the oil drain plug say? I'm having an issue with leakage right now that others here on Rennlist believe may be the plug.
Old 04-26-2012, 12:08 AM
Academictech
Academictech's Avatar
like a good french wine...there are no bad years for 993's.....only thing bad about a 993 is it's a**
Old 04-26-2012, 12:26 AM
Mike J
Mike J's Avatar
Check out the TSB's on pcarworkshop - http://www.pcarworkshop.com/index.ph...C_Parts_Guides
Cheers,
Mike
Old 04-26-2012, 08:53 AM
SC2993
SC2993's Avatar
Interesting post, the VIN for my car is specifcally mentioned in the TSB. My VIN ends in 0225 and was manufactured on 1/27/1994 so the dates mentioned are spot on. In the preceding years I have since replaced the suspension components because of age.
Old 04-26-2012, 02:05 PM
The Brewmeister
Cheers,
Mike
Thanks Mike! Your site is an outstanding resource.
Quick Reply: 993 bad years?
