[Fixed] Help needed : total instrument failure
Hi folks,
My instruments decided today is a good day to die and while I think I've covered the obvious, I probably missed something. Here's the situation.
Started the car after lunch and noticed that the oil pressure gauge didn't move at all; it indicates as off. Tapped on the glass a few times and it moved a bit, but continued to read way below normal. Engine sounds perfectly fine and with a little rev the oil pressure builds up, but seems to be 50% low (if normal is top of the scale under load then it's in the middle under load now). Then I noticed the tachometer, fuel level, and oil level are also at the bottom of the scale.
What doesn't work
- Speedometer reads as off
- Tachometer reads as off
- Fuel reads as off
- Oil level reads as off? (never got really warm, so difficult to tell w/ sketchy gauge to begin with)
- Oil pressure reads 50% below normal
- No warning lights when turned on
- No warning lights while running (parking brake, rear wing)
EDIT
- Brake lights don't work
- Can't raise rear spoiler
- CCU doesn't work
What does work
- Turn signal indicators
- Instrument lights
- High beam indicator
- Clock works (not warning lights)
- Fog indicator light works
- Car starts, drives
- Headlights, fog lights
- I checked fuses (12 and 18), both fine.
- I checked the grounding strap behind the fuel gauge, looks ok; nut is tight, not pinched, cut, etc
- I checked the connections at the back of the gauges and all appear tight (didn't disconnect and clean)
Sounds like ignition switch to me. Is there anything else I should try first? Any way to confirm the ignition diagnosis, and if it is that is there anything I should be aware of safety-wise? I still need to get home
Thanks!
-mb
What doesn't work
- Fuel reads as off
EDIT
- CCU doesn't work
What does work
- Instrument lights
Thanks!
-mb
Last edited by mattjb; 04-05-2012 at 02:29 PM. Reason: spent some more time diagnosing
Pull relay R11, and insert a fresh standard '53' relay .... or pull the identical relay from the horn, etc for a swap ( or test the R11 in the horn location) .... or jump terminals 30 to 87 on the R11 socket.
If that does not cure the problem, then I suspect that the "Central Informer" module is cooked .... it is located above the ignition key, in an aluminium case about a cigarette pack size.
Enso (07-08-2020)
Thank you Garth, you just made my day!
-mb
MB,
Glad it worked out for you ..... in my case, it was only the fuel gauge level that was porked - which turned out to be a dead track on the central informer PC board: wished it had been the relay , as you have to crawl under the steering wheel to grope for the latter.
