Changing Power Steering Fluid
What Mike J said, then when you refill, start the car, & move the wheel L/R quite a few time, to circulate the fluid, then repeat till the fluid is clean.
Last time I did the "flush" it took 2l of fluid.
The factory website does not jive with your post. It says the opposite is true. The CHF 202 was about $15.00.
http://www.lufteknic.com/Merchant2/m..._Code=PS_Fluid
Hey Mike, your correct, my parts guy has dyslexia! In any case it would seem that both fluids are used by Porsche, or at least were in the past. There was some discussion on this forum of one vs the other...see link
https://rennlist.com/forums/993-turb...chf-202-a.html
But either has to be better than the red ATF fluid I sucked out of there!
Jim
Jim
