Do I need a top end rebuild - UPDATE Compression and Leak Down Numbers are in.
I agree about disclosing. Here is what I sent to everyone that was interested in the car. I add oil twice a year, and not a quart each time, and average 2500 mixed highway and street miles. so mile oil consumption is OK.
1995 Porsche 993 Cabriolet
Color – Riviera Blue
Interior – Black
Top – Black
Miles – 104,713
VIN – WP0CA2990SS343552
Clear Title
Clean Carfax
Exterior
All upgrades were done at time of restoration with miles of 95, 072 on or around 03-11-09.
All parts are NEW unless otherwise noted
• Full repaint from top to bottom (pictures of entire process on disc)
• Headlight washer delete
• Factory Aerokit 1B Sideskits
• Stock decklid with new spoiler wall and painted center grill in matte black
• Euro Twin Turbo front bumper (no bumperettes)
• Euro rear bumper with bumperette delete
• Headlight lenses
• HID headlamps
• Factory Twin Turbo airducts
• Factory Euro clear lenses
• Sliverknit trunk carpet in black (from a 98 993 with low miles) not Perlon
• All body seals replaced (door handles, mirrors, bumpers, hood crest and front fender)
• Windscreen washers and seals
• Windscreen wiper arms refurbished and new blades installed
• SIGLA windscreen with new inner and outer seals
• Top in black (previous owner had new one installed)
• Factory stone guards
• Sport Classic II wheels (2 piece)
• Powder coated calipers Fly Yellow (removed from car, sandblasted, coated and reinstalled)
• Twin Turbo Colgan Bra
INTERIOR
• Full Sliverknit carpet kit installed (New from GAHH)
• Riviera Blue seatbelts
• Rear Seat Delete covered in new Sliverknit carpet
• Alpine iDA-X305 with satellite radio and i-Pod capabilities
• Clarion 700 watt 4 channel amplifier mounted under RSD
• Clarion speakers all around
• Factory wind deflector
• Coco mats in black with blue accents
• Rebuilt odometer with both new gears
• Power mirror switch
• Center dash air vent
• 2 new lighted keys with leather pouches and immobilizer fobs
MECHANICALS
All done at 95,072 miles on or around the date of 03-11-09 with the motor and transmission removed from the car. All items are NEW
• Clutch
• Flywheel
• Pressure Plate
• Throw out bearing
• Master slave cylinder
• Slave cylinder hose
• Transmission drain and fill
• 15W-50 Mobil 1 oil
• Primary and secondary oil filters
• Fuel filter
• Air filter
• Motorsound airbox
• Rear main seal
• Inner and outer CV boots
• Motor mounts (C4 Style)
• Transmission mount
• Catalytic convertor heat shield
• Valve cover gaskets (Upper and Lower)
• Timing chain cover gaskets
• Distrbutor secondary drive belt
• Belts replaced (all 3)
• Belt tensioner
• 12 spark plugs replaced
• 12 new spark plug wires
• Distributor caps and rotors replaced
• MOTO-VAC fuel injection flush
• RS shifter
• Fisterd D Motorsports Golden Rod (Shift Rod)
• New front shift rod
• Replaced all shifter bushings
• New power steering Rack
• Replaced power steering pump belt
• Steering rack boot
• Steering rack brace(Porsche update for 18” wheels)
• Brake Pads
• Brake Rotors
• Spiders
• Sensors
• Flush and fill brake fluid
• Recharge AC system
• Full suspension replacement – Viper Bob supplied
1. ROW MO30 Springs
2. Bilstiein HD Shocks
3. New sway bars
• Fister D Stage II Sport Mufflers
• Porsche Wide Oval polished stainless steel muffler tips
• Hood shocks/deck lid shocks
• Engine harness recall done
• Top locking motor recall done
• New engine bay decals
• 3 new belts in boot
• DME Relay (in glove box)
03-07-11 – Self performed service with Rennlister 993BillW at 102,036 miles
• 3 belts (Porsche OEM)
• Air filter
• Cabin air filter
• Fuel filter
• Oil filters (1 large 1 small)
• Mobil 1 oil 15-50
• Brake Fluid flush
• Master cylinder flush
The car just won the top award The Sponsorship Award at Porsche Palooza in Eureka Springs, AR in November, 2011. Over 100 cars in the car show.
The car was chosen to be the 993 example at the unveiling of the new 991. Each model of the 911 was asked to be on the floor of the dealership during the event.
I have all receipts for work performed as well as over 100 pictures detailing the restoration process. There are absolutely no chips, scrapes, dings, rubs or damage to the paint. The interior is as clean. Most people think the car is brand new. The car has been driven a total of 8031 miles since the restoration/mechanicals were done. The only issues with the care are
1. The CCU cut out on me once but worked fine after I pulled it and cleaned the contacts. The CCU’s are supposed to be finicky in 993’s it cut out on me when I was on a 9 hour trip for a minute or so. I felt it was necessary to mention in order to have full disclosure. It also may be the high speed fan resistor which is known to fail. It has worked with no issues so I haven’t researched it any further.
2. The odometer quit working when the previous owner had it. I replaced the odometer gears and all is functioning properly. I made the previous owner refund a portion of my purchase price through small claims court. We never had a decision by a judge we came to a meeting of the minds. The odometer gears do fail in these cars and it would have not stopped me from the purchase as I was going to restore the car anyways. I just believe in full disclosure. There is no reflection of this in the Carfax or the title just informing you in the spirit of full disclosure.
Interior – Black
Top – Black
Miles – 104,713
Clear Title
Clean Carfax
Exterior
• Headlight lenses
• HID headlamps
INTERIOR
MECHANICALS
• Clutch
• Flywheel
• Pressure Plate
• Throw out bearing
• Fuel filter
• Air filter
• Motorsound airbox
• Rear main seal
• Belt tensioner
• RS shifter
• Brake Pads
• Brake Rotors
• Spiders
• Sensors
1. ROW MO30 Springs
3. New sway bars
• Air filter
• Cabin air filter
• Fuel filter
• Mobil 1 oil 15-50
• Brake Fluid flush
Originally Posted by Arena993
Originally Posted by geolab
cylinder 1 or 2 ?
The cylinder you are talking about is cylinder 2.
Of the ten 993's i have had on my lift, SEVEN had a cylinder base seepage, either cylinder 1 or 2, never any other cylinder.
my 993 included... I changed to thicker oil at that time, and it did not leak from there anymore. Not a solution, but ...all to say that this , to me, is common on cyl 1 or 2, why ? I do not know
I hope this does not worry you. I am very solemn
FYI.
My crude approximation of the cylinder numbering. Arrow showing (normal) driving direction...
Front of car
3 ^ 6
2 | 5
1 | 4
Back of car
Firing order 162435 (double checked via AOW's login name...)
Front of car
3 ^ 6
2 | 5
1 | 4
Back of car
Damn, Mike, I had no idea you were selling Sir Smurfs-A-Lot. Your car is one of my favorites. Hmm....
I hope everything works out for you. If your buyer falls out, let me know.
I like your honesty, its good Mike!
Its not worth taking it apart to change out the cylinder base ring (if that is where its coming from).
There are a few potential spots to leak around that area, including the oil return tubes. Have you definitely pinpointed it to the base O rings?
If it was my car, I would do what you are doing, disclose and see what happens. I would not deeply discount much more unless the oil was pouring out of the engine - if it drips at times, then sometimes changing weights/brands of oil can help it, but its always cheaper to put oil in the car than fix the smaller leaks, especially one this deep.
If you are selling at a discount, I am sure there will be buyers out there willing to ignore it.
On your leakdown, you did have one piston a bit high - 8% - what did your mechanic say about that one?
Cheers,
Mike
Cheers,
Mike
Mike, say it isn't so!
Does the 997 come in Rivi Blue?
I see some seepage under may car at the base of the cylinder, but I am hoping it is just being blown around as the cam chain cover gasket is leaking on the same side (I know that the cam cover is behind the engine - but I am keeping a positive atitude.) I've cleaned it up and will watch it. I assume you have cleaned yours up and verified that is the source.
I do too. We need to get together for the TBL.
This is helpful. I knew AOW's was the firing order, but didn't know the cylinder orientation.
When I bought the car it had been sitting for not quite a year. The PO did drive it to meet the transporter and I drove it 17 miles to my mechanic. My mechanic said that it is a bit odd that one cylinder is higher, but it may be because of it not being driven. Of course as documented here the odometer was broken when I bought the car which is why I wanted the leakdown. I am going to have it done again to see where it stands. If it needs a TOR it's just part of the 993 ownership. I was glad to see that the 8% leakdown was not on the cylinder that's leaking, or at least I hope it's not. I really don't have a ton of knowledge around the engine I'm more paint, body, interior.
Mike
Mike
Mike
Wow. I just noticed this post.
I was one of the people that spoke to Mike about buying his rivi blue cab (we spoke on Saturday). After reflecting on it over the weekend I decided to pass due to the fact that I'd have to find a storage place to park it. I figured that unless I could have it in my garage at home it wasn't meant to be.
The price being discussed was VERY fair to the buyer. I am far from being a mechanic but I wouldn't let this issue detract you from considering his car due to:
1) the price is already discounted severely to market value
2) uniqueness of this car
3) you are buying the seller as well as buying the car. I.E. Mike is a standup guy and u are buying his reputation.
I'm guessing from reading this post that not many really knew the car was available for sale. It seems many here have an interest in it. Do consider it. It's a GREAT car.
