993 Forum 1995-1998
Steering rack binding?
Old Feb 20, 2012 | 03:56 AM
Toto111's Avatar
Toto111
Default Steering rack binding?
In what is becoming a never-ending search I had a fellow Rennlinster and 993 owner have a look at an interstate c4 I am seriously considering.
Seems a reasonable car. 113km, manual, white over black.
Very standard and unmolested (at this stage).
Air con seems to be an issue which should be easily resolved, but I'm a little concerned about the steering rack.
When driving straight and turning the wheel it seems that the steering "binds" and then lets go at about the 10 and 2 o'clock positions. Certainly nothing that makes the car undriveable but nonetheless needs to be addressed at some stage.
Anyone experience the same thing or any suggestions apart from the rack?
Old Feb 20, 2012 | 07:39 AM
Garth S's Avatar
Garth S
Being a C4, I would check the front diff seals for signs of leakage ..... and check lube level if possible: the differential must 'do its thing' when turning.
The half shafts can have an impact .... but if that bad, you would be driven mad by the clicking & snapping from one or more of the CV's.
LCR ball joints are a lesser third on the list ..... and the top strut bearing comes into play ..... but very rarely I think.
Old Feb 20, 2012 | 09:08 AM
DAVISRILEY's Avatar
DAVISRILEY
My 964 did that. I replaced the rack with a 993 rack, and all was normal. Never took it apart to figure anything out.
Old Feb 20, 2012 | 09:56 AM
Linnm's Avatar
Linnm
Check power steering belt, make sure fluid is up to level
Old Feb 20, 2012 | 04:09 PM
Toto111's Avatar
Toto111
Thanks for the feedback. If negotiations go well today i'll arrange a PPI and see what the outcome is. Didn't even consider the diff!
