Door Seal Replacement - That was easy . . .
I want to replace my door seal as well... the bottom is badly worn from my clumsy feet dragging across it over the years. How hard is it to remove the old seal?
I am also thinking to replace the seal around the passenger door - again worn/torn from passengers closing the door holding the top of the window frame.
Where did you get the seal - Pelican?
Sorry for the crappy pictures.
Used 3M Black Super Weatherstrip adhesive. Pushed the new seal in place starting on the upper right corner where the seal is formed at a right angle. Went in easily - except there is a stiff portion of the seal at the bottom front that is more difficult to seat. Added a little extra glue there and shut the door. It is now drying in the very hot garage. Got up to near 100 degrees here today.
Thanks for the help from the various posts here...
Time for a cold one
FYI... the door seals from the 964/911 coupe will fit a 993. Current Pelican price for aftermarket is $53.50 each with discount dealer price for OE at $108 each.
While the 993 seals (a 964 part # that was not used on the 964?) are about $227 each for OE from a discount dealer.
The difference between the seals is that the 993 seal is flat and smooth where the 911 seal is round and ribbed. This makes the 993 seals have a left or right fitment where the round 911 seal fits either side. With the 911 seal the door needs a little more effort to close because you have to compress the thicker seal.
I have had a 911 seal on the drivers side for a year or 2 with no leaks or wind noise. I thought I was buying a 993 seal from a rennlister until I got the package with the 911 part # on it, but it was only $40 so OK with me either way. Part # for the 911 seal is 911 531 095 03.
I am not saying to use the incorrect part for your car but for a little over $100 you can do both sides with the "wrong" seals or over $500 for the right seals.
funny how small changes by Porsche can equate to $$$
we can source these also
This previous thread appears to be focused on the door seal that mounts in the jam and seals the door when it's closed.
I need to replace the seal that mounts on the door, running up and over the window frame.
Having a tough time finding this...can someone help?
Did you get a quote from Sunset?
They specialize in used parts like Pelican Parts?
Yes, the guys in Oregon. Send an email to BobMcCarthy@sunsetimports.com, he responds quick. One of the cheapest places for Porsche parts anywhere - and they are a dealer.
cheers,
Mike
cheers,
Mike
replacing just the door seal section that gets worn when feet pass over the door thre
Mike J Did you get a quote from Sunset?
This seal is $248.37
Quote#123024
We would need to order in(normally 4-5 days to get)
Thank You!
Bob McCarthy
Thought I would give this thread a bump and keep Al's (Cemoto's) good karma rolling.
The left door seal on my arctic silver C2S, in otherwise good condition, had the typical tears/fraying along the bottom from PO's dragging themselves in and out of the car... After recently installing stainless door sills (thank you Keith at Prestige Parts UK), it was time to replace the old seals.
I considered patching with a 964 seal, but wanted clean and seamless solution. Thankfully Pelican Parts offers an alternative to the genuine Porsche seal which they sell for $607.50, and for just $142.25 you can purchase an OEM replacement. http://www.pelicanparts.com/cgi-bin/...&I1.x=0&I1.y=0
This is a very easy install, but removing the old glue with goo gone took over an hour. Still I was very pleased to get all the old glue up down to the shining paint, and may just leave the new seal in place without the glue. It's a perfect fit, and doesn't appear to be going anywhere.
If you've read this far down and you are interested in simply patching your left seal, like Al (who replaced his seal and graciously gave away the used one for patching) I will ship my old seal free to the first RL member in CONUS that PM's me. Now it's time for a beer!
Old door seal was frayed and torn
Pulled the door seal off and removed the glue with Goo Gone
Happy with new OEM (but not genuine Porsche) door seal from Pelican for $142.25
Old genuine Porsche door seal will make a nice few patches for someone...
The beer!
The beer!
Jim, I didn't patch mine I replaced it. The patch suggestion Garth tried. I don't recall ever hearing back how it turned out.
My tt when I bought it had a new door seal installed and it is of a variety I've never seen before. It is ribbed like a condom.
I'm glad to know you are happy with the Pelican product, I just ordered one right now.
Thanks!
Thanks!
