Spark plug wire location on Distributor caps
IIRC, when I replaced the DC on my TT(single distributor setup), the cylinder numbers were indicated on the top of cap next to its corresponding post. Does that help?
in addition to Mr. Bing's post above, on many 993s there is a diagram on the electrical box cover on the left side of the engine bay
the OE Beru wires also have cylinder #s on them
or are you looking for a photo of the actual wire routing?
Here you go. These are still as wired by the Porsche factory showing the over and under routing, if it matters.
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Beru-Ignition-Cables/i-p4Q9Vrq/0/X2/Porsche-993-Distributor-Cap-XL.jpg)
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Beru-Ignition-Cables/i-Rdktg9c/0/XL/Porsche-993-Primary-XL.jpg)
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Beru-Ignition-Cables/i-rRrSdk4/0/XL/Porsche-993-Secondary-XL.jpg)
With new Beru Silicone Copper Cables...
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Beru-Ignition-Cables/i-jvmqmDc/0/XL/Distributor-Cap-Suppressor-Cap-XL.jpg)
I just did my 60k service last weekend and thought about that too...however after reading the DIY article, I think I will just send mine off for 170 bucks and have someone else redo it...looks like a PITA job.
Replacement of the distributor belt is an easy DIY with parts costing under $15 for the belt, pin and O-ring. Doing it yourself gives you the chance to check all parts while giving the distributor a good cleaning.
My distributor gallery on SmugMug really isn't a DIY, but there are a few good tips on it such as distributor removal and a solution of the secondary distributor plug at the bottom.
Kent
It is a PITA job! You have someone that will do the job for $170.00 sounds cheep? If I had someone to do it for that price I would have had them do it. But as Alex said in another post this is an opportunity to clean up the top of my engine.
It was not required to do the distributor rebuild. The distributor can be removed by just removing a couple of components...blower fan and associated tubing.
I believe he went with the full set of cables.
And since they are pre-assembled, how one routes the wires to the distributor caps can make all the difference between them being just right or too tight.
Speaking of "data", I once asked at what point those caps fail. I never did get an answer. Mind you, we'd need a large enough sample of failures for any data to be meaningful.
Remember, those new set of Bosch points I once installed that didn't work. Parts either fail during the early stages of life or they last a long time.
As you know, we prefer to change them prior to failure. A proactive maintenance approach. IIRC, you disagree with that approach. To each their own.
No, I don't recall you had defective points.... but comparing new defective points to old plug resistors? Really?
Interesting.
Edit: wait, I see your point (no pun). You are saying that you had new defective Bosch points so your new plug resisitor could also suffer from infant mortaility.
Still, interesting.
