Last efforts before calling the hook...'95 C2, won't start after engine R&R.
#106
Seared
Andreas, that was my thought in my first post... I can't see how that difference occurs just due to cam timing. I can see left or right being different, but within the same bank each cylinder should be the same.
I'm wondering what additional issue is causing that difference.
#108
Good question, do not know. Intake/Exhaust spacing is of course fixed, so if the cam is twisted out of timing, it possible that you hit a place where at least one valve is open when the piston is close to the top. But to do it for BOTH sides, failure analysis would show its less likely.
I talked to Travis on the phone, he will try to get a boroscope and check the pistons, as well as do a preliminary timing check to see how far out the cams are. We talked about the use of the impact gun, it sounds to me like it was not very hard to get the pulley nut off, so the impacts were not substantial.
I am trying to see if I can get the time from home to run down to Seattle (road trip!) and help him setup the timing if we conclude its indeed the issue.
Cheers,
Mike
Cheers,
Mike
#109
I have also just finished this activity and am listening with great interest. My line of thought follows the last couple of reply's. It sounds as though there is a cam timing issue and perhaps (for some reason) the cam bolt was not tightened sufficiently on one side allowing for slipping or no minimal cam rotation. This is exactly why I put in pins even though I was advised against it, fortunately, my engine (95) was built with the 964 gear/sprocket assembly and all I needed to do was but a couple of pins.
Unfortunately, I have a leak at the cam gasket and need to drop the engine again to fix.
Best of luck...
Best of luck...
#110
Cheers,
Mike
Cheers,
Mike
Wouldn't the easier check be to line up TDC on #1 and conduct a leak down? It'll tell you where the leak is, if there is a leak.
Another step is to remove both intake and exhaust rocker arm while conducting the leakdown. This tell you if the valve kissed the piston and is now bent.
If test #2 is good while test #1 is bad, then you just have to re-time the engine. Either way you HAVE to conduct a leakdown to see if there is any bent valve from the cam slip.
#111
Great idea if he has a leakdown tester AND a compressor. I am skyping him later today, will talk about it.
Keep it coming guys!
Cheers,
Mike
Cheers,
Mike
#112
So maybe the first 95's had the pins - and I know that some 96's have the key slots in the cams, and the updated sprockets without the ability to positive lock. I know that because that is what my 96' had - I backdated the sprockets, but the camshafts still had the woodruf keyway.
We even saw one 97 with one keyed cam and one non-keyed.
really good of you to offer drive down Mike!
#113
Cheers,
Mike
Cheers,
Mike
Just got a email about this being on sale, was thinking about getting it.
http://www.harborfreight.com/catalog...lt?q=borescope
#114
Seared
Mike,
Your offer to drive down and assist Rennlist's newest engine-dropper speaks volumes about your character.
Also, your nuts arrived in today's mail. Thank you!
Andreas
Andreas
#115
Turns out I can get the time, so its a matter of if its needed, and logistics. Weather forcasts put snow starting tonight. I would have to take the truck down, which is good from a weather point of view, lousy for fuel (damn V10's!!).
I am going to talk to Travis tonight and we will figure out a game plan.
Cheers,
Mike
#116
I will post if I am coming down for sure, have a few people to visit as well.
Cheers,
Mike
#117
I actually just got home with one of those. However I think the camera head is going to be too big to get through the spark plug holes..but hopefully I can get a look at the tops of the pistons to look for contact.
Yes, this really is a great community here! I forgot how exactly I found Rennlist (was a lurking member for a while before pulling the trigger), but it's been a joy to be a part of. I am looking forward to being able to contribute more, but for now I still have plenty to learn.
Anyway if Mike winds up coming down, anyone is more than welcome to drop by for a mini get-together, I can get some beer and pizzas or something like that..
#118
We may need a few indexing pins this weekend if we retime, and he does not have any. I can use the head off a sparkplug in a crunch, anyone local to Seattle have indexing pins?
#119
Yes, it's a great community! Sadly, we are also very spread out.
#120
