Do you have to change oil every year....
#31
Moderator
Well, I would run say 10 track days a year and each day would end up being about 250 miles depending. So 2500 plus another 2500 to / from track and general street miles = about 5000 a year total. Northeast is tough - snow probably from early November through Early April...
#32
#33
Moderator
After many years and with confirmation via oil analysis my process worked out fine. I can't buy onto the equation that 1 track mile = 100 street miles. Stretching legs at the track is probably better for a car than stop & go street miles or short trips. As to pushing it, I'd say 1:01 at Lime Rock in a stock 997 C2S is moving along
#35
After many years and with confirmation via oil analysis my process worked out fine. I can't buy onto the equation that 1 track mile = 100 street miles. Stretching legs at the track is probably better for a car than stop & go street miles or short trips. As to pushing it, I'd say 1:01 at Lime Rock in a stock 997 C2S is moving along ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I spent nearly 20 years racing SCCA at the National level including a number of years in Showroom Stock, so my opinion is based on that experience, for what it's worth.
But I've sort of strayed from the oil topic......
Cheers.
Dave
#36
I don't believe it's been mentioned in this thread but an important aspect is to get the engine up to temperature before shutting it down. Condensation caused by incomplete warm-ups will cause a lot of problems with plugs, oil contamination, etc. Also not mentioned is the waste of premature filter changes (which are extremely efficient in doing their job). On low mileage between oil changes, I just skip the filter changes 'til next time. IMHO, the small amount of old oil left in the filters is insignificant.
#37
This is Rrennlist! We don't stray heere!
I tend to agree, but the added cost of the filters is pretty small as compared with the time/trouble to do the oil change.
#38
Something else to add to the equation, what about a car that burns a quart every 1500 miles. Assuming you add a quart every 1500 miles, at 15,000 miles you have put 10 new quarts in. The new oil obviously mixes with the old oil, but there is some percentage of new oil that gets added between full changes.
It hurts my head to think about all that, so I basically just add 1/2 quart when I need it (~1200-1500 miles) and a full change at around 5k miles. That is what I did with my last 911 (1980 SC) and it ran like a top, so I haven't deviated from that mentality, although the engineer in me thinks it is overkill.
