CEL: faults for all 4 o2 sensors
I did a search but couldn't find anyone else reporting this exact problem. I have a CEL and the diagnotic shows 8 fault codes, 2 each for the 4 o2 sensors. Interested in best guesses as to what might be going on. Car is running fine, 56k miles on engine.
i had a similar issue...out of nowhere a bunch of 02 codes.
I reset the connection to the ecu, tightened every ground I could find, and reset (and cleaned with electrical cleaner) all the 02 plugs.
Problems gone.
Free and may solve your problem.
Problems gone.
Any other trouble lights or electrical issues? A good start when more than 1 electrical gremlin pops up is the main ground strap at the battery. It may look brand new, but the strap and connection builds up resistance over time. Replaced mine and electrical gremlins disappeared.
I think he means the plug into the ECU itself (under driver's seat IINM).
Give you an excuse to clean out all the $$$ hidden under the seat. I think I found $4 in change under there when I took my seats out to clean them.
Essentially pull the computer off the floor, undo the connection, blow on the connectors old school nintendo style, and put it all back together.
Thanks for the tip -- this worked, at least temporarily. Now the engine is out for a top-end so we'll see if it comes back in the spring.
