Installed a new headunit...what to do with that pesky BT mic? Answered w/ pics!
I installed my Parrot mic on the column w/o having to take off anything.
See pics in this thread.
https://rennlist.com/forums/showthre...ferrerid=59194
Just as a reference.
Ed
Ed
I installed a JVC KD-AVX77 full-touch screen unit in the car - great device, and when blanked out no ***** or buttons - just a black surface. Very clean!
Have not upgraded the Turbo yet - running out of cash! :-)
Cheers,
Mike
Ed
Ed
That def helps. Thanks! I think this might be the option I go with if I can't squeeze the mic thru the steering column area because I don't want to have to disconnect the cord from the back of the HU.
Kent,
The plug of the mic was small enough to fit through the opening. I kind of went through from the right side of the column, grabbed the plug from behind and wiggled it up. I replaced all gauge lights with led's so I had easy access to the inside of the dash.
Good luck with your install. The mic location works ok in the cab although anything higher then 45mph gets too much wind interference and other party hears nothing but wind. I'm thinking of buying some fuzzy sleeves to cover it up. Otherwise it works great.
Ed
Ed
It's been awhile, but I recall turning the steering wheel to access those screws. Undid the screws and cover to help with tach removal.
My car came with the Bat Phone option, and there is a mic installed in the dash to the upper left of the tach (opposite to the dash-light dimmer). The hole is only big enough to fit the wire and plug thru, and the mic is (or I should say was) glued on. It's a pretty small mic. Wish I had a pic.
Ed - perfect info...thank you!
Jeff - exactly what I was thinking...Ill attempt this weekend and let you know what I find.
I found an Alpine HU that's nice and clean looking. streaming audio bluetooth but only single line display. I just ordered this Kenwood unit as well. Nice choice.
$249 from Amazon and $299 from Crutchfield but you get the harness with Crutchfield.....
Yeah, and honestly, after dealing with Crutchfield I wouldn't purchase anywhere else. They have great customer service and were able to answer a few questions on the phone I had when installing. Also, i ordered by phone and asked if they had any specials...I received a nice discount FYI.
Well, I decided to have a look around the steering column when I got home from work today and ended up just wiring the mic! Thanks to everyone for your comments and feedback...as Im not sure I would have experimented with the different locations and taking apart the column plastic had it not been for all of you that have gone before me!
Overall, I love the looks and functionality of this unit. Goes right in, looks the part and has the modern features that I am used to in my other cars.
