Blinker seems not as loud. Any fixes?
Mark, I hope you've ordered a P!g Pen (Cayenne) forum T-shirt.
https://rennlist.com/forums/porsche-...ng-thread.html
and to the original topic, on a more serious note...
You can try swapping out the turn signal relay. Some are louder than others.
That said, I have no idea what brand would be louder.
Also, You might see if the relay can be moved a bit. You might be able to relocate it (somewhat) to be better heard.
Full disclosure, I've never tried this but it could work.
JC Whitney has a solution for everything, including the problems you didn't know you had: http://www.jcwhitney.com/extra-loud-...wx?filterid=j1
A Radio Shack beeper in parallel with relay will also do the trick. or you can have your horn play La Cucaracha after 7 seconds of blinking. If there's enough interest I'm sure I can build that circuit.
