Opinion of Rennline adjustable gas pedal?
Addicted Specialist
I can heel/toe perfectly smoothly in my 993 with stock pedals. Remove the floor board and look inside the pedal area: you'll see the brake pedal (or is it the gas, it's been a while since I had done this??) is adjustible for height. Easy. Free. Perfect.
Edward
Edward
Hi David,
I cant be sure as I didnt install them. Im travelling now. The brake and clutch screw into the steel on those paddles but I suspect the accelerator one goes over the top of the plastic factory part - although from memory there inst a noticeable height difference with that pedal either....
Heres the link...http://www.srpracing.com/pd_993.cfm
Cheers
Cheers
2011, 993, accelerator, adjustable, aftermarket, cars, gas, installing, pedal, pedals, peddle, porsche, remove, rennline, rev2
