Dead pedal install suggestions?
I received a nice black anodized footrest (deadpedal). Essentially, it is a flat peice of anodized aluminium with holes. It came with a few screws etc but it is really a fabrication job that is up to me to figure out.
I wanted to avoid drilling into the metal of the wheelwell..but want it tight and secure when I put my weight into it...any ideas?
Super Duper Moderator
I drilled and installed mine with about 3 stainless metal screws. There is nothing to hit behind that lump by the trunk release so you're safe to drill there.
Marc
Marc
I will drill it in. Do the screws end up in a dry space or do I need to take off the fender liner and put a dab a silicone or similar?
I am looking forward to have a substntial place for my foot too.
Check out these posts from the 964 forum>>>
This one shows the sheet metal behind the carpet
https://rennlist.com/forums/964-foru...-question.html
If the 993 is the same then you might be trying to screw into the sheet metal where there are holes...
This one shows Marc's dead pedaL
https://rennlist.com/forums/964-foru...r-options.html
Thanks for the advice and the links guys. Will post picts when finished. Looks like Rennline's bends down on right to contour curve for a better fit. Mine? just a flat peice of nice metal.
Note to self...buy Rennline's "designed to fit" stuff in future.
