993 Forum 1995-1998
vibration damper
Old 08-25-2011, 01:54 PM
GPReyes
GPReyes's Avatar
Default vibration damper
ok, so mechanic says i need to replace both front vibration dampers... each costing almost 700 bucks...
i've got a 96 carrera...
anyone know any oem places that would sell cheaper online?
help!!
Old 08-25-2011, 09:07 PM
GRINBOB
GRINBOB's Avatar
If you know the part numbers GOOGLE them...You will probably find more than one.
Old 08-25-2011, 09:35 PM
nile13
nile13's Avatar
Wacha talkin bout, LeRoy?
What vibration dampers? Is he doing it together with muffler bearings and blinker fluid change?
Old 08-25-2011, 09:49 PM
Falcondrivr
Falcondrivr's Avatar
what is a vibration damper?
Old 08-25-2011, 10:05 PM
Mike J
Mike J's Avatar
Shock absorbers?
Old 08-25-2011, 10:41 PM
jimbo3
jimbo3's Avatar
Isolation for the gyroscopes.
Old 08-25-2011, 11:04 PM
nile13
nile13's Avatar
I prefer to remove gyro isolators so I can feel the gyrations better. It's also possible to replace them with custom sports gyro isolators. While there, I'd also consider replacing gyroscopes with RoW models the way things were intended.
Old 08-25-2011, 11:08 PM
funbug
funbug's Avatar
Probably the front shocks. Got a set of Bilsteins off Ebay Germany for about $700. In the process of fitting them (have already done the bushings). Not a difficult job to do yourself - there is a thread on it. Cleaning the wheel arches is taking longer than expected and is a real PITA.
Old 08-25-2011, 11:23 PM
jimbo3
jimbo3's Avatar
How do you overcome the extra stress on the phase shift linkage? Do the ROW cars have a heavier duty capacitor?
Old 08-25-2011, 11:28 PM
nile13
nile13's Avatar
As I always do. By drinking heavily.
Yes, they do. Added amount of flux makes it both heavier and more dutiful. There are drawbacks, of course, but RoW gyrations are truly excellent. That alone can atone for not properly cleaning the ISV.
Old 08-25-2011, 11:41 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
and here I thought Renault F1 was the only car with mass dampers
Old 08-25-2011, 11:49 PM
jimbo3
jimbo3's Avatar
Try the RS gyros. Expensive, but worth it if you drive anywhere near the limit. And, they're fairly easy to re-build, so it's cost-effective over the long term.
Old 08-26-2011, 01:51 AM
Floodj
Floodj's Avatar
Don't forget you need a 14mm hydrospanner with counter-rotating head to get phased shift linkage out.
Old 09-03-2011, 09:50 AM
GPReyes
GPReyes's Avatar
wow you guys are ****ing funny... maybe you should sell your 993's and get the new 991 with your comedy careers.... vibration dampers are basically front left and right shocks... sorry different language ...it's the term my german mechanic uses... i got the parts thanks for your help anyway
Old 09-03-2011, 11:39 AM
Falcondrivr
Please don't be offended. We were all just afraid there was a secret part (waiting to fail) that we had never heard of.
Quick Reply: vibration damper
