Walrod bushings
Walrod bushings
I have just installed the bushings in the control rams and need to refit them to the car. What are the torque values for all the nuts and bolts? I really do not want to over- or undertighten them. Thanks!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I typically use 40ft/lbs on the caster eccentric and 75 ft/lbs on the caster mounting stud.
Otherwise, 75ft/lbs on the long control arm forward bolt and 60ft/lbs on the aft bolt.
