Rear Suspension arm damage
Now to figure out how to dial in a little more height to avoid that scraping..
Maybe someone that has them and installed them can chime in. I'd sure like to know...be it on the Bilstein HDs or the PSS10s.
From diagrams of the PSS9/10 I found on the Bilstein site, that shock is the very nearly the same as the HD apart from the 'dial' at the bottom, and it has two locking rings above the spring perch vs the one on the HD (like mine).
Alex - you are right - you rotate the spring perch to get height adjustment, but mine are very nearly at the top of the threaded area, so fitting another locking ring would give me a little extra height. Or stiffer springs I guess - but then I would have quite different ride characteristics...
