Will 285/18 tires fit rear of narrow body?
I am too lazy to do a search.Will a 285/18 tires fit on 10 inch rims with a 65 off set fit with no rubbing issues on the rear of a narrow body?
285/30-18 tire will fit on a 10" ET65 wheel on the rear of a NB car. Had that setup on my lowered 97 (H&R/Bilstein HD) for almost two years/9000miles. No rubbing at all even during auto-x.
Tim, were you flush to the fender lip and approx how much more offset will NB tolerate with 285? Thanks
Also remember that all 285/30-18 tires, tires of any size for that matter, are not created equal in terms of exact dimensions. Different brands and models of tires can and will vary in dimension despite listing the same size.
Shouldn't be a problem. Timothy is correct that some tires are wider than others. I've run MPSC's (in 295/30-18) , BFG R1's and Hoosier R6's and have never had an issue. There will be some rubbing on the oil line if you drive extremely hard, but it's not a problem.
Mark is correct that the right side wheel hub (where the oil line is) is inset ~.2" more than the left side. Though I've never seen the tire hit the oil line w/ that set up. That's just the way they are built.
The HTR-Z IIIs are decent. great value, i.e. cheap.
They are OK performance, not the best, but for what you pay, they do the job.
I live in So Cal, so I have very little wet experience on them, but they are far better than the HTR IIs I had on my 911SC. Those were horrible.
I don't have experience with the Conti's so I cannot comment directly.
I personally like the Sumis and would probably get them again, unless something better is out at the time.
