Tranny fluid for C2 - 4.0 qts or 3.8 qts?
Changing the transmission fluid for my 993 C2 the first time today.
I note that the p-car DIY calls for 4.0 US qts of fluid but Streather call for 3.8 qts. What is your experience? Thank you.
Exactly. I fill until it runs out, close it up, work on other stuff, and double check in a few minutes. If its still leaking out, I close it up and its done.
I think its closer to 3.8 since I usually have a bit left in the can when filling. I use a pump, and some of the oil remains in the lines.
Cheers,
Mike
Cheers,
Mike
