How To Jack Up A 993
#62
If you have a lift it's far easier to lift a 993 than a 911
It's hard to see when in use but these are the buffers needed, the 4 silver ones lock into the 993 chassis and make for fool proof lifting points, the 911 chassis needs pinch weld or rubber buffers which have to be very carefully placed to avoid sensitive areas
Cheers
#63
Yet Another Floor Jack Adapter
the discontinued product made in japan.
________________________________________________________________________
"...rarely exceeding forty miles an hour. This made it one of the rarer
Porsche 911s in the world." -- H. MURAKAMI
#64
Figured I would post up my version of the OP'er's ramp idea. Ramps are made out of 2 x 8 lumber cut 24" long with an angled 45 degree edge and non skid strips applied to the bottom. Furring strip angle cut at front edge to prevent running off. Front jacking piece is 2 x 8 piece ripped down to 6" and cut to 24" length. Front edge is 18" (to match width of Front Protection Bar) with 45 degree cuts back, as you can see I routed a groove ~ one inch wide by 3/4" deep to accommodate the FPB. A one inch bolt was threaded into a drilled hole about an inch in with about an inch and a half protruding out of the bottom, this fits perfectly into the hole of my floor jack. I then bored out about 2 1/2" circle nearly 1/2" deep to allow the FPB center mounting bolt to recess itself into. To finish it off I contact cemented a scrap piece of carpeting letting it dry overnight then cutting the excess off, a quick pass over the carpeting edges with a propane torch cleaned up the edges.
Damn I want a lift...............
#65
Having almost had my neck snapped lifting a car and having the jack fall over I use a two jack method to lift my 993.
two in the front and walk back and forth until the front is up high enough. I use two jackstands with rubber pads under the front suspension mounting points and then move both jacks to the rear. I basically walk around the car and pump once each until the car is high enough. Then two more jackstands under the rear. Its not the fastest way for sure but I don't like teeter-porsches.
I really need a lift!
