Tool needed for suspension DIY
PS Armorer
Bart , Removal doesn't seem to be the problem as I have all the tools needed. It's the re-insallation when I need to get the correct torque settings. Samstag is expensive. I still need to buy a good 3/8" torque wrench. I'm looking at Snap-on. Is there any downside to using a craftsman?
PS Armorer
Ha! Just you saying to yourself "why did I buy this fu@#!%g piece of s#!t?"
I've made do with Craftsman torque wrenches (3 different sizes) for 10+ years, but they really are aggravating. The locking mechanism on the adjustment collar never stays put and on 2 out of the 3 the ratcheting mechanism doesn't work consistently. I'd consider my use "light," wrenching on my cars and motorcycles. I dont use them as ratchets or breaker bars, and I keep them in a special drawer so they don't get banged around. They are not warrantied like their regular hand tools.
I'd jump at replacing them with Snap-On (check craigslist) or something else. The Craftsman torque wrenches will work for your job at hand, but down the road if you keep using them you may be sorry.
Here's the simplest, cheapest answer that solves all problems:
All pics are below.
The stock strut nuts are 21mm, and you don't care about torque specs when removing it. So, use a 13/16" spark plug socket to remove it, which has a hex end on it. You can't use a regular 13/16" socket because the fit is too tight. It has to be a 13/16" spark plug socket. Apply breaking torque with a 7/8" closed end wrench on the hex part. Or an adjustable wrench.
For the 22mm nuts that come with the Bilstein HD setup, get one of these for $8.99 (in store price):
http://www.toolking.com/1-2-inch-dri...-sensor-socket
It is made for 22mm/.875" O2 sensors, and fits the 22mm Bilstein nut perfectly. Now you can torque to perfection and sleep soundly without spending an arm and a leg.
PLUS, it's dual use - you can use it to change out your O2 sensors when they fail.
All pics are below.
All pics are below.
All pics are below.
The o2 sensor socket is exactly whit I used worked a treat!
All pics are below.
All pics are below.
