993 Forum 1995-1998
Tool needed for suspension DIY
Old 06-24-2011, 10:13 PM
flyingchappy
flyingchappy's Avatar
Default Tool needed for suspension DIY
Does anyone know where I can get this Hazet tool for the front strut removal? I checked everywhere and it seems not to be available.
Old 06-24-2011, 10:43 PM
haygeebaby
haygeebaby's Avatar
I had the same problem. I'd recomend that you invest in a Dremel tool. One of the most handy tools to have around. Then go and buy the extra long socket pieces and cut out the hole. This is what I did. Worked perfectly. Sockets only cost around $15 dollars. I believe the Hazet tool is pretty expensive.
Good luck
Regards
Ken
Old 06-24-2011, 10:52 PM
Warpig
Warpig's Avatar
Hmm If I remember right I went to the local auto zone. they had an o2 sensor removal socket kit that was I believe free for rental.. They put the cost of the kit on your CC to secure the value of it. Then you can return the kit and get your money back. If I remember right I used one of the sockets out of the kit and it fit. The o2 sockets looked very similar to the hazet socket you pictured.
Nick
Old 06-24-2011, 11:02 PM
PNogC2S
PNogC2S's Avatar
Yep, O2 sensor socket will work. Just be sure it's not one of the ones with the really narrow groove. Needs to have a big enough cut-out.
Old 06-24-2011, 11:17 PM
skl2
skl2's Avatar
forgetting what size it is but I just googled it and found one:
http://www.shoptoolsshoptools.com/shopexd.asp?id=964
Old 06-24-2011, 11:22 PM
Van1
Van1's Avatar
Impact will buzz the nut right off.
Old 06-24-2011, 11:35 PM
Ed Hughes
Ed Hughes's Avatar
Supposedly a Matra 3186 replaces the Hazet 2593...still $50. For less that $10, you make your own.
http://www.samstagsales.com/vwaudi2.htm#suspension
Old 06-24-2011, 11:56 PM
Van1
Van1's Avatar
If you don't have access to an impact, just grind two flats onto a Craftsmen long socket, hold with a adjustable wrench, and use an allen inside of the socket. Worked like a charm on my BMW E36 M3. But on the 993 I disassembled by holding the shock shaft with vise grips (stock struts aren't worth crap so who cares about marring the metal) and using a socket on the nut. When I dissasemble my Bilsteins, all I needed to use was an impact. Didn't have one during my first suspension change but would have worked well.
Old 06-25-2011, 01:17 AM
cosmic_993
cosmic_993's Avatar
use this, from my Koni FSD post
https://rennlist.com/forums/993-foru...all-96-c2.html
the kool tool is from here....
http://www.metalnerd.com/cat05.htm ( scroll down )
bought it at...GermanAutoParts.com
Old 06-25-2011, 07:28 AM
flyingchappy
Thanks everyone.
Is the special socket tool just for removal of the Monroes or do I need it also for reassembly of the new PSS10s? I'm am looking going the direction of fabricating one on my own. Seems like the simplest cost effective solution.
Old 06-25-2011, 08:47 AM
haygeebaby
haygeebaby's Avatar
I needed two with the Bilstein HD install - removal I think is 19 and the Bilstein needed 21 - something like that. Why don't you ask someone who has done the DIY and is close to where you live to send them to you in the post - and then mail back to them. Once you've used the sockets - you don't really use them again.
Old 06-25-2011, 09:03 AM
flyingchappy
The Monroes are 21mm, but I don't know what the PSS10 are. I didn't want to be presumptuous and I figured that if someone wanted to offer they would do so. I don't mind trying to fabricate them myself albeit I don't know what size the PSS10 requires. The 'intheAir' DIY says 19mm for the HD Bilstein.
Old 06-25-2011, 09:09 AM
craig001
craig001's Avatar
Are you going to reuse the upper mounts or need anything of the old set-up? Before I decided to have my shop change out the suspension I was just planning to pull the fronts out as a unit. But I was putting in some TRG Camber mounts and picked up an extra set of upper spring keepers so I did not need to recycle any pieces parts.
Old 06-25-2011, 05:53 PM
GC96
GC96's Avatar
You can get an equivalent tool from Samstag Sales, they list the MATRA 3186 as equivalent to the Hazet socket you're looking for. I have ordered specialty tools and various Hazet from them before and have had no problems. http://www.samstagsales.com/vwaudi2.htm#suspension
GC
Old 06-25-2011, 05:57 PM
Ed Hughes
Ed Hughes's Avatar
GC
Wow, wish I'd said that....
Quick Reply: Tool needed for suspension DIY
