Options for outdated centre casette stacker
Hi all. Newbie here!
On my centre console, just behind the hand brake is an outdated (and obviously useless) 6-cassette stacker. What can I replace this with? Does the stacker come out like a module or is it integrated into the centre console? I'm thinking even a cup holder will look nicer than this especially since one of the slots is busted and looks ugly.
Thanks for any advise. Some pics would be great too.
Paul
Paul
I installed the consule tray (part #10):
http://dcauto.gotdns.com/illustration/index/135671578
I believe a lot of us did this - it is a very simple DIY and requires a screw and the pad (part #11).
You can find these several places (not just DC auto): I think Pelican, Paragon, eBay...
i was doing something with black Vinyl on another car and while I had planned to order the tray as suggesetd, all the materials were right there so I just did my own and it works/looks great.
1) removed it
2) cut a piece of wood in the size of the rectangle openning with the old cassette insert as a guide
3) glued black vinyl onto wood -wrapping the sides and corners- and placed inside openning(the vinyl wrap making the wood slightly larger than the hole actually holds it in place)
it took literally 12 mintues and been that way for about 2 years.
1) removed it
1) removed it
1) removed it
TIA
http://www.suncoastparts.com/product..._Code=993_trim
$29.95 and your problem is solved. This is a new OEM part and Suncoast ships quickly.
