How to remove interior panel for seatbelt removal
Where did you purchase your red seat belts? I have to replace my drivers side seat belt receptor and thought I might take the opportunity to replace the black seat belts at the same time. So I'm looking for both an OEM receptor and a set of front red seat belts.
Just installed a front RED set from Sunset. $386.71 delivered from OR to CT. There seems to be no OEM part number for RED rear belts for 95-98 years but I think there are aftermarket ones out there in the $500 range.
Or, you can DIY for $70. I tad controversial .....
https://rennlist.com/forums/993-foru...nder-70-a.html
The top trim on the rear side panel has 4 screws. Three are along the rear quarter glass. The fourth one is on the front side of the B-pillar. You can see it in the picture above on the right side.
Once these four screws are removed, the top trim pulls away. You can then pry the top of the side panel away from the body under the rear quarter panel glass. Once it is free there, pull the panel up and out from the bottom.
Paolo1 (07-30-2021)
Excellent. I have the rear parcel shelf freed and moveable and I'd like it out of there before attempting to lift and separate with the rear quarter panels. Is there an easy way to detach the speaker wires and the rear seat belts that are the remaining things holding on to that shelf? I have gone through all the threads and it is still a bit ambiguous in that regards. Thank you.
For the speaker wires, when you free up the rear deck panel you’ll find connectors on the speakers that pull right off.
For the seat belts, check out my Das Roll Bar Install thread. There’s some photos there and a link to a helpful thread by Spidy993.
Paolo1 (08-01-2021)
