Recaro Pole Position build
How do you tighten the fit of the cover on the pole positions? IN one picture the cover is loose and then it is nicely tight against the padding. There doesn't look like you can attach it to anything.
There is a cable that runs along the outer dia of the seat. Trust me when i say they are an absolute nightmare to fit. You pretty much get a different fit every time you put the covers on.
Here are some of the other recent recaros we have done, as you can see we do ls's most often..
![Name: Picture208.jpg
Size: 66.7 KB](https://rennlist.com/forums/attachments/993-forum/1235637d1501791993-recaro-pole-position-build-picture208.jpg)
![Name: 008.jpg
Size: 53.9 KB](https://rennlist.com/forums/attachments/993-forum/1235638d1501791993-recaro-pole-position-build-008.jpg)
![Name: dlgpyt-1.jpg
Size: 41.1 KB](https://rennlist.com/forums/attachments/993-forum/1235639d1501791993-recaro-pole-position-build-dlgpyt-1.jpg)
Also a set of custom "coupe" mats we finished for a mk2 vw jetta coupe
![Name: 008.jpg
![Name: Picture475.jpg
Size: 109.0 KB](https://rennlist.com/forums/attachments/993-forum/1235640d1501791993-recaro-pole-position-build-picture475.jpg)
