Faded out wheel "crest caps"-Whats the best option?
Yes, the holes are there for the "center cap pulling tool"
No affiliation just to present an example of tool > http://www.suncoastparts.com/product/00072192291.html
OR you could attempt to replicate with a metal wire clothes hanger. Cut it and bend it to that shape and you're good.
To wet sand, get some 1000, 1500, or 2000 grit wet-sand paper, soak it, then rub by hand. A machine won't let you follow the shape properly and will be much too aggressive. Do it by hand.
^^^^^ like snowbird said, just use some 1500 or finer, water and get any high spots smooth. Then a few coats of a good clearcoat. I over did the clearcoat and made bubbles. Don't do like me. :-)
Mine look identical to 911searcher's. And I also have no clue how to buff them, plus one is lost.
I looked at those ebay ones and will probably buy a set. But the crest looks gigantic, I'd rather have a smaller crest of an OEM cap. I also have a set of metal (substantial and heavy) black and white caps, but they don;t look as nice on a yellow car as the painted crests. So finding and buying replacement plastic crests would be great.
I guess this is as good a place as any to ask..........where do I find Center wheel caps ...black with silver badges? I may have to use the added badges found on Ebay instead..I have Fuchs..19" .on my 2010 CS...I would assume the center caps are same as regular Porsche centers? and if not...at least the crests would be?
thanks
fredz
thanks
fredz
Try a fine cloth, an old t-shirt or micro fiber, and Brasso. Yes, Brasso. It is a very fine compound that works great for all things plastic. Also great for fine scratches on signal lenses. My caps looked exactly like yours but look like new now. Careful with any solvents as this is a very soft plastic cover the crests and will melt.
Is that the only way to pull the cap off ?
![](http://i57.tinypic.com/vgneoo.jpg)
Is there a reason why the seemingly overcomplicated suncoast version would work better ?
Looks likes a tool that is better for finding the elusive gspot than something to remove my tire cap, non ?
I guess you'd have to remove the cap + crest as a unit to clearcoat ?
What clearcoat ? How did you apply ? was it a spray ?
I will try the Brasso method so I don't need to remove the cap + crest
psiddle (01-20-2020)
