Oil Change
#31
The biggest annoyance for me is getting the placement of the lift arm correct back by the oil thermostat so oil doesn't hit it and splatter all over. I had it down pretty well with the Bend-Pak lift but I just changed to a MaxJax and Mike and I changed the oil on his car a couple of weeks ago and I've never spilled as much oil as I did that time. The lift arms on the Bend-Pak come out from the center, the arms on the MaxJax go in from the outside. I'll do better next time.
#32
Bill, I was wondering about this when I bought my Maxjax, after reading about two post lift issues when changing the oil, but after I set it up and put the car on the lift it seems to clear the drain area - but just. I suppose it depends on the distance that you have between the posts - what's yours?
The skirts on Mike's '95 are a little different than on my '97 plus his are painted so I was a little cautious about moving them out of the way. Also I've found if I use 2 hockey pucks on the rears it gives me more room to work.
#33
I leave the oil line in place and use a pair of filter pliers on the small filter to remove it, then hand tighten the new filter. No leaks or issues after 3 small filter changes. Do not buy the cheap adjustable filter pliers, you want the smaller name brand ones like Mac or Snap On.
Some may argue that you get more oil out by removing the line, I drain the oil tank hot and raise the front end up while draining, seems to empty the oil cooler if you are patient enough.
Insulated thick rubber gloves are a must if you try to drain it while still hot.
#34
I like to remove the oil line from the engine block because it only takes at the most a minute (I use two long extensions so I actually thread the socket through the wheel spokes all the way inward to undo the 13mm bolt). I then use my trusty 24" monster screwdriver to loosen the oil line. A fair amount of oil comes out, so that is worth the effort in my books....but of course to each his own. The also makes room to unscrew the filter.
Cheers,
Mike
Cheers,
Mike
#35
While I have always removed the oil line in the past, I tried removing it without detaching the line yesterday. It works and is simple. A little less room to work in, but it is doable.
#36
http://www.gregsmithequipment.com/Pr...ctCode=HT52008
#37
I don't jack up the car to do an oil change. I just lie down next to the car on an old towel, remove the rocker panel cover, drain the oil tank, and change the filter. Being closer to the floor there is shorter distance to the drain pan, hence less splash. I also drain the engine without jacking the car, using an old pie pan as a deflector to prevent oiling everything in sight. I jack the car only to change the engine oil filter.
#38
Not only do I take the wheel off, I take the whole right rocker cover off. Gives me a chance to clean it...mmm mmm good!
To take the wheel off, you have to jack the car up, so I always change the little engine filter as well. I don't know why people choose to skip this. I don't take off the return tube (2 more failure points), but maybe every 5th oil change in order to change the O-rings? I have a steel cap wrench like the one posted previously. Sometimes I line parts of it with 400 grit sandpaper to prevent slippage. A 10" - 14" socket extension will allow you to work around the drain tube.
If you do it right, you can time every other annual oil change to coincide with your two-year brake fluid change interval. Again, since the wheel is off, you only got three more wheels to remove for the brake work. Also doing a power steering fluid change while I'm in there. Be sure to let the wife know that you're doing three things at once, so that you're working on the car "less often."
#39
#40
This is exactly the one I use, it's just mine is taller for the full sized lift.
Cheers,
Mike
Cheers,
Mike
Mike, I went searching for one of those for a mid-rise lift and found this. I think it would be perfect. $49 seems like a great solution.
#41
During my first oil change, I was thinking "a guy REALLY has to want to change his oil in order to get through all the steps required for these cars". Geeez.
Here's the tool I bought to change the engine mounted filter. It worked great and was inexpensive ($6):
from Autozone, it's the 76 mm. diameter oil filter "B" cap wrench with 14 flutes. Part number is 25401.
Nick
#43
No need to remove the oil line & dick with the O-rings to access the small filter .... remove the orange, molded silicone air hose, and fit the 14 facet wrench and 12" 3/8 extension to the filter: the filter slides out over the sway bar ...
#44
King of Cool
