CEL/readiness question
Does the OBD trip a check engine light only AFTER all the readiness codes are set? I am missing only 1 readiness code (o2 sensor) and am wondering once it is set if I will get a code for the SAI. All my systems with the exception of the oxygen sensor say "ready" on my scanner.
I mean, do all readiness monitors need to be set before it throws a "check engine light." Or if you have a fault, will it trip a light immediately, even if all monitors are not set. I do have a previous SAI fault code. I am afraid that once the last readiness monitor is set (02 sensor) the CEL will come on for the SAI. Is that how it works?
My smog is due next week. I have been reading up on the strategies for setting the monitors. I just don't want to waste my time if the OBD is waiting to throw the code.
Hi,
Our cars (OBD ii -- 1996...) have 8 readiness monitors. The SLOWEST to 'set' are the ones for the cats. The fastest to 'set' are the EZ ones, (so to speak), e.g. the misfire monitor, etc.
Once a particular readiness monitor has 'set' - then the system that THAT monitor is ....yes, monitoring... needs to be working, within parameters, otherwise you'll first get a pending code and then a full-blown DTC (stored) code ...yes, a CEL.
Think about it, why would the misfire monitor have to wait until the cats are 'set' before telling you that you have a bad spark-plug?
IMHO, you should do the 'BMW drive cycle' (do a search) and get that last, pesky, cat-monitor to 'set' and then skootch over to your friendly Emissions/Inspection station. I would NOT turn off the car because the SAI is 'checked' during the first few minutes after a 'cold-start'. With the car already running, it has already checked the SAI when you first started the car - so why give it a second chance to possibly ruin your day? IMHO, 'wasting' a couple of bucks of gas, by letting it idle, whilst the tech-guyz get their wires in order, is better than getting a CEL. Also, by letting it idle, you're being sorta passive-aggressive in letting them know that they can't lolly-gag and need to attend to you lickety-split.
If some (lazy/on-my-cellphone) tech mumbles "Hey man, I suggest you turn your car off until we're ready" I would simply say: "MY car is ready ...why aren't you?" and leave it running so as to make the point.
Just my $0.02,
Gerry
Just my $0.02,
Gerry
Same for Texas for cars of the age of a 993. It is important that ANY "failed" code will let you fail the inspection. The "flexibility" is provided only for "not ready" codes. Check with your DPS on your local regulation.
