Porsche 993 irregular reving
I have a 1995 Porsche 993 Carrera Cabrio with 95k.
During cold starts there is irregular reving.
It revs from 1000-2000 and then back to 1000 for about a minute.
It cycles every 3 seconds.
This stops after about a minute.
Has anyone else experienced this problem?
Appreciate your help.
Porsche_993
Porsche_993
Have you tried cleaning out the ISV the butterfly valve might be clogged up. On a pre-varioram it's a piece of cake to take it off, soak the valve end in thinners etc, dry off and then replace.
Can't believe "Porsche 993" user name wasn't taken.
When the car is stone cold, it will rev up & down, then settle on a fast idle. But 2000 is a little on the high side.
First, clean out the ICV, & make sure all maintenance is up to date.
Then check for any vacuum leaks, the little black vacuum hoses love to pop out, they mostly hide under the intake plenum.
Oh damn. I just did this DIY several days ago and should have taken some pics for the pre-varioram folks. It's slightly different than the DIY Robin wrote up. The ISV is rotated 180 deg compared to Vram engines.
It's the big round thing on top of the intake with the corrugated hose going to it.
Thanks Mike for the pic. You are correct. Very easy job on the 95. I loosened the back clamp first, then I removed the ISV with that big giant hose attached....much easier than releasing the big hose from the valve.
Noodle Jr.
Is it possible that the ISV can go bad? i have some issues with high revs at startup and then when restarting a warmed engine the revs sometimes go high then come down slowly.
