993 Forum 1995-1998
Porsches that should not use E10 gasoline (10% ethanol), 993 included.
Old 03-09-2011, 01:40 PM
2Many Cars
2Many Cars's Avatar
Geo is exactly right. Octane is about resistance to detonation, nothing more. IIRC the test to establish octane involves a one cylinder rig where the compression can be gradually increased to determine the point at which pre-ignition starts to occur. Additives are used to increase octane, the most effective of which is probably tetraethyl lead, now banned almost everywhere except for some racing applications. (remember high test gas being referred to as "Ethyl" by some old timers?) Ethanol also helps increase the octane rating but its main use is to cut the petroleum content and to reduce evaporative emissions, especially in the winter months (aka "winter blend"). The downside is ethanol has less energy content than gasoline and as Geo correctly observes it's both corrosive and tends to attract/hold water, neither of which is good for older fuel systems with plastics that aren't designed for use with ethanol. The government in its infinite wisdom has determined that up to 10% ethanol is safe but that's debatable for older cars. Over time we'll find out, possibly the hard way, if that's a correct assumption. There's not much you can do about it so I just stick with gas from major companies that have pledged to sell only tier one (high quality) gas - Chevron, Shell and Phillips.
Old 03-09-2011, 02:01 PM
matt777
matt777's Avatar
Perhaps its been mentioned already, but ethanol blended fuels have a lower btu/energy value IIRC. This means less mpg and less power does it not?
Old 03-09-2011, 03:14 PM
Flying Finn
King of Cool
Flying Finn's Avatar
Thanks everyone, lot of good valuable info.
This 10% ethanol gas is corrosive, less ebergy content and tends to attract water, I mean, what's not to like..?
Old 03-09-2011, 03:47 PM
matt777
matt777's Avatar
plus good food crops are turned to fuel crops (but that is a whole other conversation)
Old 03-09-2011, 04:33 PM
Mike J
Mike J's Avatar
I HATE the ethanol ****, and luckily our Chevron 94 Octane gas here as none.....for now.
Old 03-09-2011, 04:37 PM
Makmov
Makmov's Avatar
I really don't have much of an Option. That has been all I have found is 10% no ethanol free gasoline.
Makmov
Makmov's Avatar
oh stop the madness.
Old 03-09-2011, 05:00 PM
race911
race911's Avatar
I can't speak to the power aspect (related--what you can do with E85), but the lower fuel economy is a given. My friend used to travel all the time between the Bay Area and Seattle, about monthly. He bought a Yukon about when CA fuel became oxygenated (MTBE or Ethanol), and got ~17MPG. Basically freeway cruising at 70-75. Fill up in Oregon, which then did not sell oxygenated fuel? Magically it approached 20MPG. He was putting 40-50K mi/yr. on the thing, and tracked his mileage religiously.
Old 03-09-2011, 05:17 PM
David in Chicago
David in Chicago's Avatar
No, it's exactly the right conversation. Anyone seen the inflation statistics on food - especially corn - lately? Funny thing about burning your food supply.
Regards to all.
Old 03-09-2011, 07:27 PM
Leon993
Leon993's Avatar
ethanol....the biggest political boondoggle in energy policy!
Freeman, you can thank Jeb and Dubya Bush for monopolizing ethanol in FL gas stations. Sorry bro.
Old 03-09-2011, 08:08 PM
matt777
matt777's Avatar
Regards to all.
We won't be able to afford food (some can't now) but we'll have crappy fuel for our cars. Its a trade-off.
Old 03-09-2011, 08:22 PM
Slow Guy
Slow Guy's Avatar
I think it's because he's going up-hill to Seattle and coming back down-hill to SF, just look at any map and figure that out.....
Old 03-09-2011, 08:39 PM
race911
race911's Avatar
Which of course makes sense since you'd likely fill up in Ashland or Medford on your way to Seattle........................ (I get that there's a 1K drop from there to Portland, but it's not like dropping off the Sierras like I'm doing coming back from skiing.)
Old 03-09-2011, 09:48 PM
racer
racer's Avatar
Sounds like you won't like the Fed plan to roll out 15% ethanol content fuel then
Old 03-09-2011, 10:11 PM
Quadcammer
Quadcammer's Avatar
Received 1,406 Likes on 814 Posts
I believe thats been scrapped for now.
Quick Reply: Porsches that should not use E10 gasoline (10% ethanol), 993 included.
