View Poll Results: Have you experienced a broken distributor belt?
Yes
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
15
7.50%
No
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
185
92.50%
Voters: 200. You may not vote on this poll
How many have broken their distributor belt?
Porsche "blew" it on our 993s. Remember on the Fuhrman, 4Cam engines you could "stop" one of the distributors from firing. These Porsches had a "kill" switch for each of the distributors, that would prevent misfiring as to alluded to here. A switch on the dash for each of the distributors would allow the driver to "test" the dual-plug engine. I remember testing a 1964 Carrera 2, stopping one of the distributors from firing dropped the RPM by about 200RPM, at speed.
It would be good to have... any technical wizards able to convert our dual plug 993s to a similar system?
Bert
Bert
Bert
Bert
Bert
Bert
Cheers,
Mike
Gunter makes a good point, the bearings are odd-ball, and apparently the source is consider confidential, but this is something that us DIY types should have available.
Cheers,
Mike
only belt we've seen available is a Gates product.
as previously mentioned, Porsche does not supply it.
Seen failures but not on my own 964 or 993s over the years. Fortunately, no catastrophic results but as Mike J outlined, this is a matter of luck.
Voted no...
Voted no...
Seems the age of the belt in our cars should be considered. I had mine replaced a couple of years ago at 40k miles. I guess that could have been premature but it made me feel better.
chuck
chuck
Figures I would be in the "had-it-happen crowd." If you search you can see pic of my cap that looked like some alien death ray got ahold of it. It went at about 112k. Fortunately, nothing else seem to be amiss. I noticed there wasn't as much power as before and took it right in.
here was the fix
used ball brg NSK 6201-08DDU, but there are SKF/NTN/*** equivalents.
Basically a double rubber sealed 6201 ball brg.
These brgs are the same dimensionally except for the ID wich is 0.5mm dia. larger.
Prepare the brgs in advance by wrapping 0.25mm thick shim stock of appropriate x-y dimension around the shaft, and apply a bit of retaining compound to the ID of the brg so that the shim/sleeve is glued to the ID of the brg.
You will need a blind brg removal tool to remove the olds brgs.
I think the brgs were around $15 ea.
Cheers Guy
My bearing crapped out at 57K miles, which caused the belt to snap. I was ready to replace the belt at my 60K service, but the bearing problem pulled that in by a few thousand miles.
When it happened I got the random-misfire code immediately. Pulled into a parking lot, diagnosed it pretty quickly as secondary distributor problem, and pulled the coil. It was down on power on the way home, but no additional damage.
