Sportec Stage 2 3.8L for 993 C4?
Anyone had any experience with this?
http://www.sportec.ch/page3443.html
First hand experience feedback preferred
Couldnt find anything searching, not sure if I missed it. Sorry if this has already been discussed (if so, anyone have the link?)
Cheers
Alex
Cheers
Alex
Basis: 3.6l 210kW (286 PS) MKB: M64/20-24
Hubraumerhöhung auf 3.8l
Pleuelbearbeitung
Verdichtungsoptimierung
Zylinderkopfbearbeitung
Spezielle Ventilfedern
Sportnockenwellen
Motorendichtsatz
Auslitern
Zusatzölkühler
Increase in displacement to 3.8 liter
Reworked con rods
Optimized compression ratio
Reworked cilinder heads
Special valve springs
Sports cams
Gasket set
Combustion chamber volume equalisation
Additional oil cooler
It is mentioned nowhere however that the increased displacement is to be achieved through a longer stroke crank.
BTW Sportec have a very good reputation in Europe, Swiss laws are very strict on modifications/safety/emissions which means there's no room for amateurs.
Click the british flag in the top left corner of the website and you will see this:
Performance stage 2 - 3.6l 235kW (320 hp) EC: M64/20-24
Part number: 30 11 02 605
•Engine Base: 3.6l 210kW (286 hp) EC: M64/20-24
•Stroker kit for 3.8ltr.
•Modified conrods
•Compression ratio
•Ported heads
•Sport cams
•Gasket kit
•Oilkooler
•ECU upgrade
Max. Performance:
235 kW (320 hp) @ 6300 RPM
Max. Torque:
380 Nm @ 4750 RPM
Max. Speed:
approx. 287 km/h
Max. Acceleration:
approx. 4.7 Seconds 0-100 km/h
I think the "modified con rods" is the key to the "stroker" kit to increase displacment.
•Modified conrods
•Compression ratio
•Ported heads
•Sport cams
•Gasket kit
•Oilkooler
•ECU upgrade
Max. Performance:
Max. Torque:
380 Nm @ 4750 RPM
Max. Speed:
approx. 287 km/h
Max. Acceleration:
They actually increase the stroke on the crank, and typically shorten the rods.
Therefore, you need both
Thanks everyone for beating me to the clarification.
Ultimately, you have to ask yourself what ~40HP is worth. I'd gladly deal with a stock 3.6L in the yellow car, and give up the whopping 4mph terminal speed down the front straight, if it hadn't come with the car.
Recently, a guy posted some Thunderhill video from a 500+HP 993 turbo, where his top speed was about 8MPH more than my mere 315. Yes, I'm getting off of T15 quicker, and he's not taking it as deep as he could; but any of these engine modifications are terribly expensive for the net gain.
Thanks for all the feedback
This mod is pricey. Have read a bit about sportecs reputation but no experienced feedback.
Have been doing more research, and The more I look into it, the more it seems that the best value for money mods for my '95 C4 are:
- Bilstein pss-10 suspension upgrade
- Cup air box/ Steve wong ecu / performance exhaust with sport cats
- reduce weight
Thoughts?
- reduce weight
Thoughts?
yes, those are good mods.
Also, great bang for the buck are the golden rod from FDM, the chris walrod front LCA bushings, and getting the tie rods "pinned".
